« 1 2 (3)
Re: Diff
From sydney australia
at the moment,my sunny has an a14 with an a15 crank in it,a mild cam,the a14 pistons machined down fit the block,too much compression,l16 valves,gx competition twin valve springs,extractors,a 32/36 dgv weber,an a14 4 speed,a h190 diff from a c22 van with a 4.1:1 ratio,200b brakes & struts,a 200b steering arm for more negative camber,adjustable castor arms,14x6 mags,& it is BEIGE.plans include a 1598 cc a15 with 180 hp,270 mm discs & alloy calipers,maybe a 5 speed,rear discs,gazelle swaybars front & rear.it's also got a dash from a sunny coupe for the tacho.i'm going to be doing circuit racing with it,just lapdashes & hillclimbs,& don't plan to paint it as it's such an innocent colour.i haven't got any photos of it yet,but do plan to get an album from the brancos for the photos i have of my sunny,the 1200 sedan i had,the 2 1200 coupes & the 1000 coupe,all of them race cars.i need to let people see them to prove i've actually done all this,i've said so much,on so many things i need to prove it,i think.
Posted on: 2002/8/23 10:32
Re: Diff
From Wanganui, New Zealand
What head are you using on this motor b310gx?
Posted on: 2002/8/23 10:36
Re: Diff
From LISBOA, PORTUGAL
I am going to post my pictures some minutes from now.
So by now you run out of revs in 4th gear?
What is the top speed?
I estimate that mine can be doing something like 106-110 Mph (overreving and down the hill).
Ricardo
Posted on: 2002/8/23 10:45
Re: Diff
yes,it does run out of revs easily,though it revs to about 7000 on the tacho.i've got a spare 5 speed at the moment,which i'll put into it soon,it's a f5w60l box.the head is an a14 closed chamber non-pollution one.it's also been shaved slightly.with the flat top pistons,& the small combustion chambers,it's got about 11.5:1 compression.even shell optimax 98 octane fuel with wynn's race boost in it doesn't stop it pinging.i need to fit the twin webers & the n12 electronic distributor to it to combat the hiroshima hammer dancing,but as it's my only transport at the moment,i'm putting off all these mods.once i fix up the rust in my sunny panel van,i can do all these things.
Posted on: 2002/8/23 10:59
Re: Diff
My car is only about 10:1 compression but the piston rings are dead of old age. I use mine all the time too, even if i can use another 2 newer cars, this is always my favourite, once i made almost 500 Km and almost always with the pedal to the metal.
Ricardo.
Posted on: 2002/8/23 11:07
« 1 2 (3)
