c20 diff into sunny b310
From H Town NZ
I have a 1982 b310 sunny (square headlights) with A15 and 5 speed box and have the opportunity to buy a nissan vanette c20 diff.
I have been told these diffs go in with no mods, is this true? Also, what is a good price to pay for the diff?
Thanks!!
Posted on: 2005/7/19 9:44
Re: c20 diff into sunny b310
From H Town NZ
...it is lsd
Posted on: 2005/7/19 9:46
From Christchurch. NZ
It shouldn't be LSD unless someone has changed, it should be slightly wider than the B310 by about 40mm, I think and the spring platforms on the C20 diff are wider. There are a couple of different diffs in the C20's also, one is a H165 (8 bolt) and the other is a H190 (10 bolt). As for price, it depends where you are.
Posted on: 2005/7/19 10:13
From H Town NZ
It is definately original lsd. Do you know anyone that has done the conversion?
I got the idea here: http://www.binary.co.nz/lynx.html
Posted on: 2005/7/19 10:32
From H Town NZ
Posted on: 2005/7/19 10:34
By reading that, I take it that you are in NZ?
Posted on: 2005/7/19 11:18
From H Town NZ
Hamilton born and raised!
Posted on: 2005/7/19 11:38
From H Town NZ
anyone done this before?
Posted on: 2005/7/20 5:26
From Christchurch, New Zealand
im interested in this as well, anyone know? im gonna need a bigger diff for when the l20b b310 is going.
Posted on: 2005/7/20 7:03
From Christchurch NZ
It's not hard if you can fabricate and weld. You may have to swap to wheels with a differnt off set.
Posted on: 2005/7/20 10:34
Forced Induction!
