1200 Coupe Vs Sedan
From Los Angeles, California
I need the front doors for my 1200 sedan 2dr and i've found one but its the coupe fastback. Does anyone know if there the same???
Posted on: 2005/8/8 22:37
Re: 1200 Coupe Vs Sedan
From Newscastle, Australia
no the frames are different.
The 2 door sedan uses the same windscreen angle as the 4 door.
The coupe windscreen angle is laid more flat, therefore the different door frames.
You can use a coupe door but cut the frame off and attach a 4 door frame, but youll need to weld in an extra length for the width of the door...as the 4-door doors are shorter. Does that all make sense, sorry but Im a mixed up Skippy the bush Kangaroo...still on a high from yesterday race practice.
Posted on: 2005/8/8 23:31
Dont die wondering.....
From Adelaide. SA
Hey there, I'm going thgrough the same thing on my 2 door at the moment. I'm using the frames from the old "dented and rusty doors" and putting them on coupe door shells... EASY. cheers. Adam
Posted on: 2005/8/9 0:51
check this out... I have my doors for my 2dr sedan but the previous owner took the windows off and replaced it with plexiglass. Can i use the fastback window, rail, and swivel glass.
Posted on: 2005/8/9 5:28
The glass has a different shape ...
2-dr sedan and 2-dr coupe have the same length door, and the outside skin is the same. That's about it.
Posted on: 2005/8/9 5:32
