(1) 2 3 »
anyone drift with your dat?
hi all...
i've seen ppl drag with their dat
how bout drift?
will it hurt your car much?
(i scare of abroken driveshaft, broken diff, etc)
can we drift with standart diff? (no lsd)
cause it seems hard to find one lsd diff that can fit directly to my car without mod
Posted on: 2005/9/2 5:42
Re: anyone drift with your dat?
From The garage, NZ
Hey. You beat me to it. I was just about to ask if anyone else has drifted their dat be4.
I have drfited it before. Not on a track or profesionally but backroads. It slides quite easy with the small tyres but some times it just doesnt. Hope to get some more power into the Dat so i can get some more angle.
Cheater
Posted on: 2005/9/2 5:46
Quite a regular
From Adelaide, Australia
Yes you can drift without an LSD. In fact a lot of people who teach people wanting to learn drifting will say you can find the car is a little more forgiving without an LSD (i.e less likely to spin). The only time you'll find it becoming something you need is if your compete and/or you are wanting to link several corners in one drift.
As for wear and tear, this will rise exponentially, if you're going to drift, you WILL break things. Engine wear will be the first of your troubles, but your gearbox, diff, driveshaft (not quite so much), clutch, tires (especially!) and brakes will all wear out a lot quicker.
I don't drift myself, but I have close mates who do compete in the Drift Australia/Toyo Drift Nats and I see how much work they put into maintenance.
A word of advice, you really should know/be prepared to put a lot of work into your car to keep it running. Otherwise, it's a great friendly sport and tons of fun so good luck!
Posted on: 2005/9/2 5:51
wow..
gearbox problem..thats what i worried most
in here my country, a nice B310 5 speed will be the same or more expensive then whole second-hand B310....
so anyone can share their car setting of their drift dat? :)
i mean most basic setting..
Posted on: 2005/9/2 6:19
From penrith
not particularly drifing..
but power over i do a few of them
ne1 see that datto in the drifts on telly? drifted pretty well for a DATTO!
Posted on: 2005/9/2 9:38
From mildura, victoria
dattos can do anythink!!
Posted on: 2005/9/3 8:55
From Adelaide
anything can drift, just some things are better than others. I think 1200's, 1000's, sunny's, 120y's etc would be harder to drift than many other cars due to their short wheelbase. An LSD (or most likely locker) is one of the most important aspects of a drift car, and is one of the first things you do if you want to seriously drift a car. An open wheeler is not going to cut the mustard.
Posted on: 2005/9/4 4:55
From brisbane
The wheelbase is a bit short. However, there are some photos of a blue long wheel base ute drifting on the site if you do a search.
Matty
Posted on: 2005/9/5 8:04
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From penrith,sydney,aus
with a bit of ca power you will do it easily Open in new window
Posted on: 2005/9/5 8:37
From sydney
Haha thats right its quite easy in the ute i could hold 3rd gear drift from side to side heaps of a control but its nuthin like silvia.
Posted on: 2005/9/5 8:43
(1) 2 3 »
