Browsing this Thread:   7 Anonymous Users
(1) 2 3 4 ... 6 »
turbo a-series.....who has what and how hard does it go
From ipswich
im in the proccess of build a turbo a12 its about a few weeks from completiong and i just wanted to know what i shud expect from my turbo configureation. like hp and performance
i have built the motor to run a turbo, heavily modified the ignition, am using a 32/36 webber as a draw thru setup with a t28 tubo and am gettin the head work to suit the turbo and run on premium and to opporate to around 9, 10 grand
Posted on: 2005/9/4 12:17
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Re: turbo a-series.....who has what and how hard does it go
What have you done to your ignition?
Posted on: 2005/9/4 12:26
From ipswich
crane cams points converter, accel super coil, iradium spark plugs, clear hi performace v8 dizzy cap with matching rotor and two sets of top gun leads
Posted on: 2005/9/4 12:39
datsun 1200 ute
What engine you running again?
Posted on: 2005/9/4 12:47
From ipswich
a12 with a14 head
Posted on: 2005/9/4 12:51
datsun 1200 ute
So what am I missing? or whats your secret?
Posted on: 2005/9/4 12:53
From ipswich
interested are we? its my little secret. my rev range is from way under 500rpm ( tacho barely reads anything) to 8000rpm ( which is the limit of my tacho) and that with stock valvetrain
Posted on: 2005/9/4 13:09
datsun 1200 ute
Ohhhhkay buddy. Best of luck. Should be hectik with that rev range."my rev range is from way under 500rpm " WTF raw power I'm guessing.
Posted on: 2005/9/4 13:17
From ipswich
hows that hyundia manifold coming along? i got mine to fit, hope ure not using the efi setup that came with it becouse they are teribly unreliable and that is from personal experence.
my turbo bolted straight up with only minor mods and with enough firewall clearance
Posted on: 2005/9/4 13:23
datsun 1200 ute
Yep definately the battery.
Either that or something else is only 40% charged
Posted on: 2005/9/4 13:28
(1) 2 3 4 ... 6 »
