Does the L series 63 series dogleg boxes have the same ratio as the A series?
From Christchurch NZ
The reason I ask is the tech section has the ratios for the A series boxes, but not the L's. I have reason to belive that the speedo in my L20b 310 coupe is inaccurate. I tapped it right out yesterday, and would like to calculate just how fast I was actualy going.
Unfortunatly, none of my manuals cover the 63 dogleg box.
Posted on: 2005/9/9 23:06
Forced Induction!
Re: Does the L series 63 series dogleg boxes have the same ratio as the A series?
From Millgrove Vic OZ
Ratios are either 3.382, 2.013, 1.312, 1:1, 0.854 or 3.657, 2.177, 1.419, 1.:1, 0.852.
Ratios depend on weight of original vehicle the box is fitted too, or payload if fitted to a commercial vehicle.
Posted on: 2005/9/13 1:31
Cheers Feral
From Melbourne, VIC
If you have access to a GPS you can calculate your speed that way. GPS will detect even small speedo inaccuracies. My speedo is waaaay out, but I have never copped a speeding fine yet.
Posted on: 2005/9/13 2:22
Speed costs money. How fast do you want to go?
God only knows what car it came from originally. I see that the difference is only .002, so the difference is inconsquential.
Posted on: 2005/9/13 8:26
Forced Induction!
From Alabama, U.S.A.
Get a police officer to test your spped with a radar . I f you yalk to them right they will be glad to do this. then record this info with your tachometer.
Posted on: 2005/9/14 3:10
