A14 pistons
Quite a regular
From Finland
I can
Posted on: 2002/9/25 20:40
A14 Turbo Power
Re: A14 pistons
Webmaster
From Lisbon - Portugal
Webmaster
Hi,
Can you upload a bigger photo of your A14, looks like a left hand drive with webers.
What intake manifold did you use?
thanks
daniel
Posted on: 2002/9/25 21:14
Keep them alive and sideways!
Re: A14 pistons
From Melbourne, Australia
love to see a pic of the twin headlights too
welcome to the club "flying finn"
Posted on: 2002/9/25 23:03
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: A14 pistons
From Brisbane, Australia
finn, you may not have to import them. go to a parts shop and have a look through a piston catalog for similar spec pistons. The easiest ones to fit will be ones with the same gudgeon pin diameter, then check compression height (height from gudgeon pin to top of piston), and check the diameter of the piston. Last thing to check is the design of the piston crown - eg dome, flat top, dished...
I have used Mitsubishi 4G32 pistons in an A14 before with .020 or .030" (.5-.75mm) milled off the crown. I think standard size 4G32 piston is +.040" (1mm) for the A14. but these may not be available in Finland??
Posted on: 2002/9/26 2:02
Re: A14 pistons
From Brisbane
Just out of curiousity what about the E15 pistons, are they any help??
e15 and a15 have identical sized piston diameters....hope this helps.
http://www.npr-america.com/catalog/nissan.htm#17
Posted on: 2002/9/26 2:23
