Mini Me now with 181rwkw
From Canberra
After some mid week tuning this week @ Autotech in Canberra the 1200 ute is now putting out 181rwkw at a fairly mild 12psi.
We are taking it out to Wakefield tomorrow (hopefully the weather holds up) to get some times on it. Should be fun!
Posted on: 2005/10/20 2:42
www.valvebounce.com
motorsport and performance forum
Re: Mini Me now with 181rwkw
From penrith
nice effort in the lil ute..
wats the specs of the motor to be puttin out that much?
wat ratio diff centre to?
Posted on: 2005/10/20 10:17
From South East QLD
shoot out mode ?
Posted on: 2005/10/20 13:50
From Newscastle, Australia
Wakefield times let me guess........mid 1.15's any other takers????
your main prob will be getting power down.
Posted on: 2005/10/21 0:14
Dont die wondering.....
From Bunbury Western Australia
jeeeeezus that must be close to 2.4 kilos per horsepower!
Posted on: 2005/10/21 1:37
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Canberra
Didn't quite manage the 15s but close. No problems with wheel spin but more with bad understeer.
He has put D01Js on the back but have alot of difficulty getting serious rubber on the front, i.e. Semi-Slicks in 195s for a 16" rim.
Another problem is lifting one of the rear wheels causing the one to spin on one or two corners. A decent sway bar will be going on to try and fix that a little. Any other ideas?
As for mods, S13 SR20DET, Microtech ECU, GCG GT28 turbo (not the S15 T28), Aftermarket filter and custom mandrel bent exhaust, diff is a borg warner LSD (out of a VN V8) 3.9 ratio. All fully engineered and street legal.
Slightly off topic but I managed a 1:10 is the S15 - Oh Yeah!
Posted on: 2005/10/21 14:49
www.valvebounce.com
From Gold Coast, Australia
is the VNSS diff similar too the skyline R31 borg warner? i know the ratio is 3.9 also but not sure about LSD. what should i expect to pay for a ss diff disk to disk? what ratio do s13's run standard is the ratio's similar eg. apparentley with standard ute diff and s13 box the engine runs 4000rpm at 100km/h in 5th.
Posted on: 2005/10/22 9:12
From Canberra
Not sure of the difference between the R31 and VN diffs.
We got the SS LSD disk to disk shortened and installed drive away for 3K engineered. S13's had something like 3.8, 4.1 any maybe even a 4.4 but I can't be sure.
I ran a CA18DET 1200 ute with the locked 1200 diff before going to the conversion above with the S13 box and it didn't rev that high from memory (could be wrong!)
I will have some pics up in the next couple of weeks of the trip to Wakefield, some real keen shots.
Posted on: 2005/10/22 9:32
www.valvebounce.com
oh k sweet. could you check with mini me what revs @ 100km/h please - will help heaps. oh and the ute is absolutley awsome - real inspiration for my ute!!
Posted on: 2005/10/22 10:44
