Browsing this Thread:
1 Anonymous Users
Alternator upgrade, gone bad? |
From Vancouver BC Canada
I found a 80 something 210 in the wreckers and noticed its alternator was 50 amps instead of my 45 amp one so I pulled it for 35 bucks.
Afetr installing it on my B210 I noticed it says on it IC REG built in.
The B210 has an external regulator. Now the CHG light stays on and I cant turn the car off with the key, I have to yank the coil lead.
Can I make this alternator work or do I have to go back?
Posted on: 2005/10/24 2:30
Quote: If at first you don't succeed, lower your standards. Keith (Mac-Datty)
Re: Alternator upgrade, gone bad? |
From Melbourne, Australia
you need to re-wire it, removing the external regulator
i did it myself staring at the wirring diagram for a while i figured it out for the 1200
but you could get an auto elec to do it for about $55
edit: (sorry thats aus dollars, um, about one hours labour whatever thats worth over there)
Posted on: 2005/10/24 3:00
does that sound normal that it would keep running after turning the key off?
Posted on: 2005/10/24 3:05
im not sure what you've done exactly but turning the key off normally cuts power to the coil which cuts spark from the motor now after doing what you've done i have no idea what implication that would have but i pressure you are putting charge through wires that your not supposed to
Posted on: 2005/10/24 12:05
From sydney australia
yes,thats completely normal.the ignition circuit is still getting power through the 2 regulators. you can fix the problem by disconnecting the external regulator,then running a wire between 2 of the wires.i can't remember what two they are,but i seem to remember they are small diameter yellow.i've done the conversion three or four times,always no problems.
Posted on: 2005/10/24 12:11
Registered Users Contentmaster Usermaster
Easy wiring fix: Datsun 1200 WiringQuote: Internal Regulator If you install an alternator with internal-regulator: disconnect the voltage regulator
connect WB wire of regulator connector to WL wire [edit: use the WR wire] of regulator connector Logically, you are connecting the "L" of new alternator to "L" of the wiring harness.
Posted on: 2005/10/25 7:56
OK, I bridged the White Blue and the White Black wires and put the alternator back in.
The CHG light now stays off. Good. The car still wont kill when the key is turned. Bad.
hmmm.
Posted on: 2005/10/25 9:02
So, after running the car after a day the difference in apparent voltage is amazing. The lights are brighter the wipers run faster the radio doesnt cut out, the cigarette lighter pops out 5 times faster, the heater dries my eyes out in minutes.
On the down side, the car is running a bit rougher in the low end and obviously the not being able to turn off the car without popping the hood is a real pain in the boot.
If anyone has done this conversion and knows what I, and the tech section here doesnt, please let us know.
I recommend this conversion highly as I have gone through 3 regulators none of which have supplied the correct voltage. 2 of which over charged at over 15.7 volts.
Posted on: 2005/10/26 3:55
From Christchurch. NZ
At the six plug connector, find the wire that goes to the s terminal on the alternator, bridge it to either the ignition feed, battery +, or you can leave it off, after trying all three options you will find about 0.2 of a volt difference. you don't want your voltage anything over 14.7 volts at any time.
Posted on: 2005/10/26 8:10
Yes, agreed.
Keith, I did the conversion recently, took the photos and created the Tech Section article. Make sure you unplug the external regulator, and leave it unplugged. If you've already done that, let me know, and I'll review the article and my 1200 and make any needed corrections.
Posted on: 2005/10/27 4:49
