1200 ute front grill is it the same as a 1200 coupe
hi to all the datto fans out there, i myself have found to be a proud owner of a 1200 coupe and i'm wondering if anyone knows, if the front grill on a 1200 ute is the same to a 1200 coupe....?
Posted on: 2005/11/1 8:50
Re: 1200 ute front grill is it the same as a 1200 coupe
Never...
1971-1973 utes had same stainless steel grille as sedan
Newer utes had a plastic grille similar -- but different -- from Coupe.
See: Datsun 1200 Exterior Trim.
Posted on: 2005/11/1 9:19
From Melbourne AUS
ive had 3 1200 utes... all 76 models..
and each has had the metal grille..
i think the transition was somewhere during 1978...
but yeah dd is right.... the ute never had the same grille as the coupe..
Posted on: 2005/11/1 9:33
1973 B110 A12
ok thanks guys, but if i bought a 1200 ute grill, will it fit straight in to the 1200 coupe
Posted on: 2005/11/1 10:15
Sedan and coupe grilles "fit" in the same opening, but have different mounting brackets. So they won't simply bolt in without making up new brackets.
Following this, it would seem likely that the 1971-1977 ute grilles would have a different mounting pattern than the 1978-up grilles. Anyone know for sure?
Posted on: 2005/11/3 5:39
From Melbourne AUS
im not 100%... but i think the later model platic ute grille's have different mounts to the metal grille...
and im wondering if perhaps late model ute grille's (plastic ones) are interchangeable with coupe grille's?
Posted on: 2005/11/3 7:03
1973 B110 A12
From Christchurch, New Zealand
I thought that the plastic ones were the same, the utes just came out with different centre badges and different use of silver in places on the grille?
Posted on: 2005/11/3 11:04
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
From Brisbane, Australia
My 1970 sedan had a plastic grille fitted when I bought it & I was able to fit an original metal grille without any changes.
Posted on: 2005/11/3 15:05
