Brain Wave
From Warburton vic
Dee put a post up a while ago on ford CFI on datsun engines. So i thank Dee for this idea.
I have a12 that i have been rebuilding as a budget build.
I have got on to some turbos at a very cheap price & this is what got me thinking.
I will fit a turbo to the A12,using the ford CFI as a blow through set up. I will use a delco computor wich i already have. The computor will will fire 1 injector up to a sertain rev range & when boost comes in the other injector will come on to keep the air/fuel mixture right. I have most of the gear & should beable to get the rest of it from pickapart it has to work. & cheap I recon i will do the whole thing for under a grand. Except the engine (I know the right people)
If any one has any sugestions feel free to coment.
Posted on: 2005/11/16 23:25
Re: Brain Wave
Experiment and see how much fuel pressure the injectors can handle without leaking - before you set your sights on a boost level. I would also experiment and see how much boost these injectors can handle before they are blown into. ( probly a bit harder than the fuel pressure test. But an air blower might work.)
The only other thing I would consider and I am sure you already realise, The problem with staged injection and boost, and the possible outcome if an injector/bank was to fail.
The more experimentation done on this CFI, will help D to see if other injectors will easily fit.
Posted on: 2005/11/17 8:14
Re: Brain Wave
From Melbourne, Australia
hmmm, nice idea, i didnt like the CFI idea before, because i dint see the benefit, but for a turbo setup it would defnately be a whole lot better than carby!
who's tuning the delco? (i get mine done by the 1600 workshop)
Posted on: 2005/11/17 21:46
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Brain Wave
From Warburton vic
I havent got that far yet its just an idea im toying with. But thanks 1200rc i no a bloke that works at the 1600 workshop.
Thanks for the advice phunk.
coops
Posted on: 2005/11/17 22:53
