Will A12 head and oil pump fit A14?? (possible dumb questions)
From Las Vegas USA
Ok guy this may seem dumb but: It appears I have found an A14 to replace the A12 in my race coupe. The A12 has what the Nismo catolog calls the H-production head , which has been professionally ported and includes the dual springs and swirl polished valves.I can have the A14 head done but I have the the header for the A12 head plus all the aforementioned parts. Also will my racing A12 oil pump fit? I have the good Nissan 550KG clutch pack as well I seem to recall that will fit. The goal here is 95HP the current A12 is at 85HP.
Finally I assume the GX Cam from my A12 will not fit.
Thanks guys
Tom
Posted on: 2005/11/16 23:47
Re: Will A12 head and oil pump fit A14?? (possible dumb questions)
From California
If your A12 camshaft has 2 gears then you can use it.
Posted on: 2005/11/17 4:04
From Las Vegas USA
OK Matt it took me a second......distributor is in a differant spot , so is drive gear. Cam is the stock A12 GX unit.
OK kiddies , anyone on the A12 head and the oil pump????
Tom
Posted on: 2005/11/17 16:30
