Valve setiings
Not too shy to talk
From Pretoria RSA
Hi there, can anyone help me on the valve clearances on a a15, need it very badly, the engine is still standard but not for long
Posted on: 2002/10/23 6:14
Re: Valve setiings
From Mudgee NSW Australia
Ive always set my valve clearances at 14 thou with engine cold on both inlet and exhuast with stock A12 and race A14 both where the same. Some people do 12 thou inlet and 14 thou exhuast shoudl be safe either way.
Cheers Andrew
Posted on: 2002/10/23 9:50
Re: Valve setiings
The A12 Valve Clearance spec is 0.014 in HOT for both intake and exhaust.
To adjust cold, use .001 smaller gap. It will loosen up as the engine heats.
Posted on: 2002/10/24 4:10
Re: Valve setiings
Not too shy to talk
From Pretoria RSA
Thank you so much, it helped and the engine is pulling, much more torque than the old a14, now for a new cam, thanks again for your reply's
Posted on: 2002/10/24 6:10
