diff ratio
From Feilding, New Zealand
does anybody know the diff ratio for a 1982 Bluebird 910 SSS. Is it 3.7, 3.9 or 4.11?
Posted on: 2005/12/20 7:30
Re: diff ratio
From Bendigo, Victoria, Australia.
take a look at the tech section
clikhere
Posted on: 2005/12/20 7:50
Re: diff ratio
The 910 was never marketed in Australia as a SSS model, but the following is probably still relevant.
Almost ALL of the Australian 910 models that were fitted with the H165 differential used the 3.9 to 1 ratio. Manual or auto, all the same.
The exception was the poverty pack four door sedans with the four speed manual trans. These had a 3.7 to 1 ratio.
Posted on: 2005/12/20 11:10
Love your Datsun.
Treat it well.
Re: diff ratio
thanks for that.
i want to change the diff in my 720 ute as i use it on the open road and i am sick of it revving its nuts off at 100k and having no guts when it comes to hills.
i wonder if an independant rear in a 720 would work?
Posted on: 2005/12/21 19:08
Re: diff ratio
From Christchurch NZ
I parted out a bluebird wagon, that had been L16 powered. Much to my disapointment the diff was 4.1:1.
Posted on: 2005/12/22 5:42
Forced Induction!
