Tuff hilux diff
From sydney
For sale: Cut down Hilux Diff suit 1200. 5.11 Ratio Center Full spool.
Condition: Perfect never been raced on, New bearing center and Axles
Price and price conditions: $1500ono
Extra Info: The 5.11 ratio in and hilux diff is very rare and perfect for drag racing and sell for $300+ alone and a full spool will set you back $400 also.
Contact Details: PM for details
Delivery & Conditions of Delivery: Pick up or delivery in Sydney areas.
Pictures:
PS. this diff has run a 10.33 in a 1200 ute before they replaced the axles and center with rear wheel drive parts 9 second pases on this diff would not be a problem.
Posted on: 2005/12/28 2:42
Re: Tuff hilux diff
From Melbourne AUS
does it still use leaf spring mount or is it setup for a 4 link rear or some other setup..
Posted on: 2005/12/28 4:12
1973 B110 A12
Re: Tuff hilux diff
From sydney
It runs the leaf spring set up the mounts would either need to be moved or move your leaf springs in.
Posted on: 2005/12/28 21:58
Re: Tuff hilux diff
From Melbourne AUS
oh ok.. with that information im assuming it was used in a car that was mini tubbed at least?
Posted on: 2005/12/29 5:41
1973 B110 A12
Re: Tuff hilux diff
From sydney
no it wasnt mini tubbed, it just had the leaf springs moved in and flared gaurds.
Posted on: 2005/12/29 21:06
Re: Tuff hilux diff
NIS15L on 2005/12/30 7:06:58
In other words, it can't be used in a 1200 without serious body mods to the car & possibly moving the spring mounts on the axle housing as well.
Is that correct?
Posted on: 2005/12/29 22:01
Love your Datsun.
Treat it well.
Re: Tuff hilux diff
From sydney
No, He only did those mods to runs a very large tyre. He was running 335s on the back.
If someone wanted to all that would have to be done is move the mounts on the diff to match the standand 1200 leaf spring position use a match offset wheel and go for gold.
Posted on: 2005/12/29 22:36
Re: Tuff hilux diff
From sutho shire
all is needed is the leaf springs 2 be moved in which isnt that hard of a job as i have succesfully done this with my ute with removal of standard mounts custom fabricated new ones and moved leafs inwards 2wards the centre about 35mm -40mm alowing wider 245's by buying the diff already made 2 suit would save lots of hours stuffing around with diff mounts ect and its cheap for a hilux diff,
Posted on: 2005/12/30 7:08
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: Tuff hilux diff
From brissie
can you give us a measure from drum to drum, where the wheel faces touches the drum? (overall length) and also the distance between the centres of the mounts,
still 5 stud i see??
Posted on: 2005/12/30 12:41
Re: Tuff hilux diff
From sydney
Thanks DVLDAT.
Il put the measure ments up 2nite.
Yes still 5 stud but its not to expensive to change them to datto stud pattern.
Posted on: 2006/1/2 21:30
