i rectum the combo my brother in laws got is pretty good, read not as good as others but damn cheap
hilux four spots over U12 pintara discs on front
bluebird disc over drums on rear (H165 or H190 diff required)
and although we havent had it in yet weve got sunny booster and urvan master cylinder for it
i think hes got 120y boost and standard master at the moment but needs to do upgrade soon!
hi-lux 4's $50-100 pair depends on luck
pintara discs maybe $25 each
bluebird disc overs varies maybe around $100 if you havent got an all you can carry for $75 place like us
we also got booster and master at same time as disc-overs but maybe $60 or 70 for both
also required, new wheel bearings when putting on rear brakes $75
and machining of disc to increase inside diammeter and also take some width out of disc $know someone? maybe $50
max. total $415
hmm doesnt sound so cheap but if you can get some stuff cheap this comes down a lot, it is a pretty good setup too remember, it gives you vented fronts with 4-spots and discs on back with drum to hook existing handbrake upto
both these brakes require 14inch wheel min. to fit
