Whats the Difference Between A12 (S) and A12
From Pakistan
My 1980 Datsun 120 Y has A12(S) engine in its bonnet(its written on the plate on firewall). what is the difference between this engine and a normal A12?
barpk
Posted on: 2002/11/5 17:36
STRONG IS STRONGEST ALONE. PERIOD
Re: Whats the Difference Between A12 (S) and A12
From Fort Worth, Texas, USA
Interesting! I have never heard of an A-12S. Doesn't really mean a lot that I haven't, I'm just saying.
Are you sure it isn't A-12A? That would be the later version of the 1200cc (ok, ok, 1170cc) engine with the short deck height of the old engine but the rearward placement of the distributor like the newer engines.
Posted on: 2002/11/5 18:08
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
From Pakistan
isnt A12 (A) 1237 CC? its in the TECH section of this site.
mine is 1171 CC, if u stand infront of the car and look into the bonnet, distributor is on your left side.
barpk
Posted on: 2002/11/5 18:19
From Melbourne, Australia
is the distributor at the front of the block or more like half way down?, what sides alternator on?
Posted on: 2002/11/6 1:59
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney
Heya dude
A12 S? Is that whats stamped on the block and the plate? Maybe the S stands for speacial? Maybe Datsun had a deal with Pakistan dealers to hot the A12 up? Dizzy has been swaped sides but stall has same CC as A12? Sounds like the later model A12. What year is your Datsun??
Scott
Posted on: 2002/11/6 5:17
From Stone Age somewhere in U.S.A.
there are 2 different A12 engines,
the first one has a bore of 73 mm. and a stroke of 70 mm. the displacement is 1171cc's, this is the one that was used in the B110 (1200) among others and made in the 1970's
the second one has a bore of 75 mm. and a stroke of 70 mm. (yes the cranks interchange) and displaces 1237cc's this one was made in the 1980's
the "S" designation is probably for a carburated designation.
when Nissan started to put fuel injection on different engines they began to use an "E" suffix to designate EFI and an"S" to designate a carburator
example: CA20S would be a CA20 with a carb, where as a CA20E would be a CA20 with EFI
Posted on: 2002/11/6 8:26
From Pakistan
my datto is 1980 B310 (RHD) and it is 1171 CC not anymore.
i think rgrinder is right about the S standing for carby setup, cos beside this i cant find anything else different,
BTW alternator(generator) is on the side where plugts r and so is the distriubutor.
barpk
Posted on: 2002/11/6 10:14
From Castro Valley,CA USA
I was about to ask what an A15 (S) is but I think the carb/efi answer sounds right.
Posted on: 2002/11/6 13:54
