engine/ carby question
From Wamboin near ACT(canberra)
i have decided 2 start doing things myself on the car, but for this problem im going 2 need some help. I will go through the problem. when im giving the ute all its got, eg taking up 2 6000 before changing gears. i go through 1, 2nd and 3rd, then when i get up to 4th the ute sorta either starves itself or floods its self. it seems 2 be starved of fuel to me. i just let it coast a bit and pump the peddle and after about 5-10 seconds its back up and running. its only when your flogging the engine but. What could be the problem here. my carby seems to be tuned pretty good. anybody got any ideas???
Posted on: 2006/2/7 7:08
Re: engine/ carby question
From South Africa, Bloemfontein
Tommy
I have experienced similar thing.
Mine has Hitachi flaptop SU's on it.
When I push it hard up to 6000rpm full throttle in first and second gear it pulls strong.
When changing to third it also pulls strong, but I noticed when in third gear full throttle and I lift my right foot about 1/4 from the throttle so that it is not wide open but a little less, the car pulls stronger than full throttle in third gear.
Posted on: 2006/2/7 9:37
1977 Datsun 1200GX
From Bendigo, Victoria, Australia.
4th gear puts the most load on the engine, this means it uses the most fuel. if its stuttering like that i'd say it was starving. check ur fuel pump, it might be a lack of pressure. it wood only be in 4th gear coz of the load on the engine which - as i sed - uses most fuel. if the pump is faulty, it might be time to upgrade to an electronic one.
u dint mention a turbo charger so i spose its not wastegate settings or turbo lag.
and if its a N/A engine then about 4psi is heaps to run it.
Posted on: 2006/2/7 10:09
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
ok so how do i check my fuel pump. and wats involved with puttin an electronic pump in. a mate got 1 put in his ute and its so loud. just a constant ticking but like you can hear it 10 metres away. is that normal or somethings wrong, cuz i dont wont mine goin like that. thanks 4 your help
Posted on: 2006/2/7 10:27
From Adelaide, Australia
Rubber mount the electric fuel pump and it wont be so loud.
Posted on: 2006/2/7 10:50
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
As for checking fuel pump, have a look at this,
http://datsun1200.com/modules/nsectio ... p?op=viewarticle&artid=34
Posted on: 2006/2/7 10:58
IPRA Build
From The Dat Cave.
Go for the obvious first and change the fuel filter. It's quick, easy & cheap to do & is the most common cause of the problem that you have.
If problems persist, see a [car] doctor. NO, if the problem remains, then you need to find the reason why more fuel flows through the main jet at full throttle, than flows through the fuel system, but my money is on the filter.
Posted on: 2006/2/7 20:11
From Alabama, U.S.A.
The question is what kinda carb is this , is this carb new , rebuilt , --- if so is the float level correct?
Posted on: 2006/2/9 1:15
