how tight should my motor be???
From durban, south africa
hey guys,
i just put my sub-assebaly together tonight put the crank in and torqued it up and i could turn it by hand, but when i put my pistons in i had to use a screw driver to turn it.
is this right? there arnt any high spots, it turn smoothly just tight
hope this is not any major problem, i just want to make sure
many thanks
nicholas
Posted on: 2004/2/2 19:27
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: how tight should my motor be???
From San Diego California
when I put my a12 together 20 years ago
it was tight too with a fresh hone on the
cylinders and new rings--as long as the rings
are set right you should have no worries
Wubbits
Posted on: 2004/2/3 3:10
From Portland, Vic
Hahaha....I'm not going near this one!
Posted on: 2004/2/3 4:19
- 1985 Datsun 1200 Ute - S5 13b Turbo
From Fort Worth, Texas, USA
I will!
To quote Goldmember: "tight, like a tiger!"
But seriously, it will get harder to turn with the pistons in. As long as you only need a wee bit of leverage to turn it you should be fine. If you have to lean on a four foot breaker bar, something is amiss. Or at least a mister.
Posted on: 2004/2/3 16:04
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
