HELP!! need to slow my heavily work 120y coupe down!!
From Wellington, New Zealand
i am wanting to know what the common disc/rotor upgrades are (without introducing the power assisted booster) for a 120y coupe with a VERY tickled motor!!
every thing is good except for the stopping power .... please share your knowledge!!
Posted on: 2004/9/12 10:53
I don't kick tyres ...... I pop 'em
Re: HELP!! need to slow my heavily work 120y coupe down!!
From Kingston , Brisbane
Try the tech section or SEARCH
Posted on: 2004/9/12 11:12
From Sydney, Australia
you shouls be able to put stanza rotors on your struts, seeing i had 120Y rotors on my stanza struits, but you'll have to look into it for yourself
Posted on: 2004/9/12 12:02
From Melbourne, Australia
go square headlight stanza struts, as a complete swap, for improved handeling also, check my www link below for conversion to 1200 (very similar to 120y)
edit: oh crap your in NZ, so you didnt get the square headlight stanza, um, tuff luck, the normal stanza strut would be a minimal upgrade, but im guessing your after something better, you may need to make up your own brake combo. i have pintara discs and hi-lux 4 spots on the front of mine
Posted on: 2004/9/12 12:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Christchurch NZ
Try 910 blubird struts. Use them with sunny (310) steering arms and lower ball joint assemblys.
Posted on: 2004/9/13 9:39
Forced Induction!
From Newscastle, Australia
RC what doyou have in the rear for brakes?
Posted on: 2004/9/13 11:10
Dont die wondering.....
