Best- price : Quality fuel pump for an a14 turbo
From Melbourne, Australia
Gday i was just woundering what the best price to quality fuel pump would be best for an a14 turbo using an IHI VJ18 turbo. cheers
Posted on: 2005/10/10 13:04
Re: Best- price : Quality fuel pump for an a14 turbo
From Sydney, Australia
If you are using a carby.. anything that can supply 3-5psi, with enough flowrate to keep up with the engine.
DONT USE A HIGH PRESSURE EFI PUMP.
Any carby-fitted 6 cylinder pump will be fine. Look at Ford/Holden parts first, at the wreckers, then go to Repco and get a price on a new one.
With fuel pump reliability is your friend (as are good filters). Stick to locally built brands that will honour their warranty.
Posted on: 2005/10/10 13:23
that depends whether its setup as suck through or blow through
Posted on: 2005/10/10 13:27
It Does What?!!
Gone over to the Dark Side...
Traded my Mustard 1200 coupe with "nissan fully automatic" a15
Intermittent wipers, air con, remote central locking and fully sick stereo for a:
"Family Car"
Mrs 1200rallycar
From Ipswich,QLD
HI chris1200t just ran out to the datto the brand name on the electric fuel pump i brought is FACET runs a low psi pump wont blow the needle and seat open on the su on idle but supplies a good load of fuel on boost .\
Cost me about 85$ with hose clamps fuel filter and 2m fuel hose
Posted on: 2005/10/10 13:31
