FLYWHEEL torque specs
Quite a regular
From Adeliade, Australia
Can anyone tell me the torque specs for bolting an a15 flywheel onto an a15?
Posted on: 2005/11/28 9:16
Re: FLYWHEEL torque specs
From bend oregon
the specs are 58-65 ft lbs
Posted on: 2005/11/28 14:23
From Newscastle, Australia
make sure you put loctite on the thread AND the head face of the bolt as well I did mine to 60ftlbs
Posted on: 2005/11/28 23:48
Dont die wondering.....
From Brisbane, Australia
I'd make sure the crank "snout" is clean (prepwash) as is the flywheel.
Then I would oil the threads and go 70ftlbs.
When they are all done up, one by one, back them off 90degrees and re-torque. You just may be surprised how much further they "do up".
I haven't lost a flywheel. . .yet.
Has anyone tried studs? As in threaded.
Posted on: 2005/11/29 1:51
