17" not worth the effort.
to fit these u need to sacrafice foot well spce. if u have a look under the front wheel arches, ther is about 15mm of clearance over the standard sized rims.
if u get 17" rims, u have a larger wheels diameter without a tyre on it. to get around this u can hit the foot well back in so that its "straight" or straighter anyway.
also note that if u do this, ur speedo will be under calibrated. meening that u'll have to go about 55km/h in a 60km/h zone.
they are possible, but its not worth the effort. 16 or 15s on a datto look huge enough.
DVLDAT wrote:
i had a mate who had 17'' but scrubbed out on full lock
full lock on a datto is about 2wice that of a normal car! these things have a tiny turning circle.
suspension will need to b looked at to. stiffer struts/springs will need to be fitted to prevent bottoming.
