a12 to a14
From Portugal
i have one a14 automatic.
i neeed to take off the A14's automatic
flexplate to install a manula gearbox and a normal cutch.
how can i do?
and what parts i need?
the a12 clutch fits the a12?
just one more.
the a14 auto flywheel is the same as the manual?
Posted on: 2006/3/12 21:15
Re: a12 to a14
From south australia
you will need
1 a munual fly whee clutchplate and pressure plate
2 a bush bearing that goes in the end of your crank shaft
3 manual peddle box and clutch cable
i think that is all you need
Posted on: 2006/3/12 22:54
Re: a12 to a14
From Portugal
Ii have all this, but dont know what is" bush bearing". can i take from another engine?
Posted on: 2006/3/13 0:03
Re: a12 to a14
the bush bearing is wat the end of your gearbox shaft slides into
you may be able to get one out of another engine it is just a metal sleave that sits in the end of the crank shaft
i ordered a new one from my local nissan dealer
Posted on: 2006/3/13 0:15
Re: a12 to a14
From Gold Coast
Referred to as the spigot bush and fits into the end of the crankshaft as stated elsewhere - the end of the gearbox input shaft slides into it when the gearbox is pushed home
Adam
Posted on: 2006/3/13 2:25
Re: a12 to a14
From Quairading, Western Australia
don't forget the manual crossmember however - I recently converted a (B210) 120Y from auto to manual - unlike a 1200 (B110) the 120Y has a uniform floorpan between auto and manual!! but has differing mounts between the two!!...
I'm guessing the B310/Sunny/210 features the same idea...
Posted on: 2006/3/13 2:50
Re: a12 to a14
From Portugal
i dont have this kind of problems, because my car is already manual.
Im thinking changing the std a12 to the usa a14 round port i have in stock.
Posted on: 2006/3/13 19:48
