Clutches
Guys does anyone know of a hydraulic clutch set up for the A series gearbox. I know I can make something up if i try but first I was wondering if there was a model that came with
one to make it easier.
Posted on: 2001/3/3 6:34
Re: Clutches
From Fort Worth, Texas, USA
All US spec cars had hydraulic clutches. I say all, all that I have seen. If you could source a gearbox and slave cylinder from the states you
would be set.
Posted on: 2001/3/3 9:54
Re: Clutches
Hi Datsohollics,
Speaking of clutches....In the world of high performance electric cars, clutches that can handle the instantaneous BIG torque that electric motors crank out, is difficult. Before I went
to direct drive (threw out the flywheel, clutch, and tranny), I went crazy looking for a clutch to handle the 500 ft. lbs. of torque my 11 inch modified Kostov motor produced. I found a
Russian fellow who custom built a setup that he claimed "Eeet Vill Not Schilp!!!" This was truly, a monster clutch, and for a while, I could stop on it in top gear from a dead stop (motor
at zero rpm) and fog the tires. But, after a while, clutch slip came into the picture. Now that I'm direct drive and am using a Ford 9 inch rear end, all is well and nothing has broken
for a while.
Just thought some might enjoy hearing a clutch tale...
See Ya.....John Wayland
Posted on: 2001/3/3 10:40
Re: Clutches
From Stone Age somewhere in U.S.A.
actually, to make things easier for, almost any left hand drive model had
hydralic clutch setups.
if you want/need one that bad, drop me a line off list I think I can find what
you need.
Posted on: 2001/3/4 1:36
