early or late model
From southern sydney "the shire"
is my 120Y an early or late model? its a 1976 (june i think) four door sedan ? i want to know because i need to know if it has early or late model engine mounts.
simon
Posted on: 2006/10/25 6:29
Re: early or late model
From Canberra
all 120Ys use the 'late model' engine mounts, only 1200 utes change
Posted on: 2006/10/25 6:36
1200 wagons change
Posted on: 2006/10/25 11:56
can anyone confirm tyrie?
Posted on: 2006/10/25 13:50
From Gold Coast Australia
If the dizzy is at the back of the block it is a late model one, but if it is more central of the block it is an early one. I'm pretty sure only 1200's had the issue with the different engine mounts.
Posted on: 2006/10/25 14:16
SR20DET Sunny for sale, click me for details
From SE Melbourne
1200 sedans and coupes are all delivered with the early crossmember. Utes were as well up till around 1975 or so.
I've never heard of an early or late 1200 wagon.
By early or late of course it is the engine. A 120Y motor is a "late" it has the dizzy the centre of the block.
The early A12 has the dizzy at the front of the block (at Cylinder 1).
The 'early' 1200 crossy has both legs the same lenght, the 'late' 1200 crossy - only delivered standard in the ute has one long and one short leg.
So if you want to fit 120Y motor in a 1200 you need the 'late' crossy.
All 120Y's are of the 'late' type (AFAIK)
Posted on: 2006/10/26 2:18
Mildman, Datsunless
From Quairading, Western Australia
I have heard that the 120Y panelvan uses the "early A12 engine and crossmember...
I know Tyrie had one... maybe he can confirm this...
all my A12's are late models..... all 5 of them!...
Posted on: 2006/10/26 2:26
From SE Melbourne
There's a photo kicking around comparing the two crossmembers - I think it's even in the tech section....I think it's one of rb20s pics. (Only cause I remember one of the x-members is green in the comparo photo)
Posted on: 2006/10/26 2:56
Mildman, Datsunless
i know that when BEV11S put an A15 in his 1200 wagon he had trouble becase he had the early engine mounts. im putting an A15 in the 120y. and i got told that all A15's have the late mounts
Posted on: 2006/10/26 5:35
From Canberra
by Mawler1 on 2006/10/26 12:26:03
hmm I dont beleive it dit, it definately had a late a12.
Posted on: 2006/10/26 5:36
