wanted; h165 diff and a14 injection manifold
From perf
looking for complete ute diff and a14 efi manifold.... anyone?? please????
Posted on: 2006/11/3 10:54
Re: wanted; h165 diff and a14 injection manifold
From Sydney , NSW
Aren't we all ......
Might have some luck with the diff, but the injection will prove to be a challenge for you!
Good luck!!
Cheers
Posted on: 2006/11/3 10:58
From Perth
Injection is easy
Send me $1900 and you can have mine
50mm quads
Old Motec fuel only comp
Manifolds (need some finishing)
Injectors
Etc
Posted on: 2006/11/3 12:15
From perf
thanks but not really of any use to me since i have a turbo set-up... computer is also too old
Posted on: 2006/11/3 13:58
If it's factory EFI you are looking for, then they are a bit hard to find, & usually are not cheap when you do find one. Patience here, really is a virtue.
The purchase price can easily be the cheapest part of the deal too, particularly if you need to buy a computer & also overhaul everything before installing it.
If you are using a GX head, then the ports in the manifold are smaller & to open them up to match may involve some welding on the runners so as to have enough metal to open into. They should work with the slightly smaller ports in A14/15 heads though.
You also need to be aware that these manifolds seem to have a habit of developing a crack in the mounting flange & port area of the first two runners. This one has cracked all the way & will need surgery to repair it. Providing additional support here would be a good idea too.
You can also see the port mismatch using the gasket marks as a guide & this was on an A14/15 head.
Are you SURE you want EFI?
Posted on: 2006/11/3 14:09
Love your Datsun.
Treat it well.
From perf
thanks for the info. in my opinion turbo and carby don't go in the same sentence! for maximum performance, reliability, tunability and security efi is the only option
Posted on: 2006/11/3 16:10
From Canberra
you can have good carby turbo setups. Its been proven to work and quite a few factory cars came with carbs and turbos
Posted on: 2006/11/4 2:23
From In front, and pulling away.Sometimes around Sydney....ish!
Dodgeman, sell me your cracked manifold! It will give Jeff something to do!!
Posted on: 2006/11/4 3:15
Lifes good when your on BOOST!
Now now, the mere posession of a photograph does not automaticly confer ownership of the photo's subject matter.
If I owned all of these I would be a very happy fellow.
Posted on: 2006/11/4 4:42
Love your Datsun.
Treat it well.
From Melbourne, Australia
dodgeman always playing games...
using photos of injection manifolds once in my possesion
Posted on: 2006/11/4 6:08
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
