Browsing this Thread:
1 Anonymous Users
WTF 3500rpm idle ? |
From adelaide
I was driving the datto today and she started idling at 1500rpm, i thought nothing of it till it climbed to 2000rpm, i gave it a rev to make sure the butterfly in the throttle body was returned fully and it picked up to 3500rpm! I disconnected the pipe from the throttle body to intercooler and put my hand over the throttle body fully, revs only dropped 500rpm ish, then i went full throttle and nothing changed. I cant hear/see any airleaks so my question is, is it only air leaks that can do this, what should i look for? Hopefully my head hasnt cracked an inlet port sucking in air as i cant find any damn leaks!
Posted on: 2007/2/17 5:28
1200 restoration project moving slower than it actually is
Re: WTF 3500rpm idle ? |
From Perth WA
yeh could be air leaks.
Buy some carby cleaner(airosol) and spray it around the inlet gaskets etc. The rpm should change if there is a leak because it is burning the carby cleaner though the leak.
What kind of setup is it? I read L20B turbo in you sig. Id it EFI or suckthough?
Posted on: 2007/2/17 6:03
Chris... Show your love and join the black hole! CLICK
From adelaide
thats a good idea beattie, ill try with some crc or similar, Yea its a custom injection system, im confused to say the least, would have thought id hear an air leak, hopefully just a blown gasket, may need to machine both manifolds flat if its blown
Posted on: 2007/2/19 4:01
From Adelaide, Australia
What gasket did you use after you killed the eazifit head gasket? Does it run with the aircleaner completely covered, if so its still sucking air to run.
Edit, sorry you did this, what manifold gasket did you use?
Posted on: 2007/2/19 4:12
cheap + fast = disaster fast + reliable = expensive cheap + reliable = stock IPRA Build
From Bendigo, Victoria, Australia.
well if its idleing with your hand covering the throt.bod then its an air leak, take the plenum (or whatever you are using, intake manifold etc) off and change all gaskets (use a bit of aviation form-a-gasket on them), retighten all nuts/bolts and start the engine again. if it idles up past normal, kick it....
Posted on: 2007/2/19 4:47
"Like a Rolling Stone" Bob Dylan
New Daily: <<<<Now For Sale. 1972 B110, 13" Bathurst mags, airbrus
From adelaide
yea just another cheap ass sprint manifold gasket brand, yea might silicone it a little too, was hoping it might be something else. I can get it to idle at 1000rpm by backing out timing but then it wont rev damn it, yes i want to kick it, its giving me the ####s at the moment, gotta have faith and stick with it but
Posted on: 2007/2/20 1:55
From adelaide
well i found my problem, cracked manifold, what could cause this???
Posted on: 2007/2/26 7:31
From Perth
Sorry to hijack your thread but what is that throttle body off it has less polution crap on it than mine
Posted on: 2007/2/26 7:37
From Sydney, Australia
too much heat ..and cooling it too fast. After welding you should get it heat treated to get all the heat stress out.
Sometimes using the wrong filler rod will contribute to that too.
'71 Green 1200 Sedan CA18DET Project 99.98% complete '71 White 1200 Sedan 20,000mi + A14T (twin 40DCOE 30/70 cam, extractors) Website: http://www.shoeys.com
Thats sucks man, that would of been one massive air leak.
Could it be too much heat when welding caused the metal next to the weld to go brittle?
Edit, beat me to it dattodude.
Posted on: 2007/2/26 7:38
