Supercharging A15
From UK
Would this supercharger be suitable for charging an A15 or do you think its a touch on the large side?
Link
Posted on: 2007/2/27 14:14
Re: Supercharging A15
From UK
Have been trawling the web and all I can find is that it is an Eaton blower on a 1.8 engine pushing 148bhp. I cant find any figures on the charger itself or its model number. Any input at all would be appreciated.
Steve
Posted on: 2007/2/27 17:05
From UK
I am also a bit confused to the reason it has 3 inlets/ outlets
Posted on: 2007/2/27 18:18
From Tamworth, NSW
Maybe 1 inlet 2 outlets. Its for a V6 motor isn't it? Did you buy it?
Posted on: 2007/2/27 18:42
Project coupe:
Just drive it
From UK
That was my first thought too. The same guy is selling the rest of the engine and it looks like an inline 4 cylinder. Another thought was that maybe it was a bypass system but with with no clutch on the SC I dont see the point.
Yes, I did buy it. For that kind of money if it wasnt any good I could sell on with no loss.
I had a chat with the guy first aswell. It seems it runs on its own oil and is "filled for life".
Posted on: 2007/2/27 18:50
From adelaide
nice perchase, maybe strip the bottom plumbing off and have a look but it makes sense to me that it can only have an inlet and an outlet unless iether is split into two for some reason
Posted on: 2007/2/27 21:59
1200 restoration project moving slower than it actually is
From UK
I found this statement on the Eaton website:-
"Additionally, the supercharger incorporates a bypass system to reduce air handling losses when boost is not required, resulting in better fuel economy"
So im thinking it may be this
Posted on: 2007/2/27 22:06
From Christchurch NZ
Yeah, I think on blowthrough supercharger set ups you need to have a bypass system.
If you will be using a carb, make sure that the blower can be used in a drawthrough aplication.
Posted on: 2007/2/28 1:32
Forced Induction!
From UK
OK, after more research I have discovered it is a bypass valve needed in a blow through system to prevent overboost during idleing, so that can be done away with.
Has anybody heard of any problems using drawthrough on an Eaton charger?
Posted on: 2007/2/28 9:23
From UK
As I am planning some engine upgrades I thought it would be a good idea to be able to keep an eye on my vitals.
Off to Ebay then and bought myself an oil temp gauge and an oil pressure gauge..
Here I have attached the senders onto the oil pump and fitted to the block to check the clearence of the adaptor to the block......
Posted on: 2007/3/1 11:37
