wanted 120y seat
Not too shy to talk
From nsw central coast
I am after a seat to suit my 120y coupe. I am after a black one if possible or if nothing comes up i would give some vinyl spray a chance.
Thanks.
Posted on: 2007/3/22 5:13
Re: wanted 120y seat
From Townsville, Qld
... or a decent looking seat cover. I've noticed something wierd about 120y coupes, the seat mounts are differnt to sedans , the mounting point is higher on the transmission tunnel side (I've finnally seen a 74 coupe to comapare to my 77 coupe and 74 and 75 sedans). Only 120y Coupe seats bolt straight up, unless you wanted to make some sort of block lie bracket to use a sedan seat or something
Posted on: 2007/3/22 5:31
From Adelaide, Australia
Would that be because the coupe ones have to come forward to get access to the rear seat?
Posted on: 2007/3/22 5:34
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
You know, i never thought of that. The first theory involved the size of the transmission tunnel and it's revision made to later model 120y's so i was assuming it was just that.
Wont have that pesky problem with rear acess when I'm done, hehehe. Mmmm, no passengers.
Posted on: 2007/3/23 5:48
From Toowoomba Q Australia
Stock pair of sedan front seats available in Toowoomba. Just come and get em out of my garage before I change my mind
Posted on: 2007/3/24 0:11
Not too shy to talk
thanks a little bit far to go. Maybe if some one around sydney or newcastle has one.
I already have rails that i can adapt if i need to.
Posted on: 2007/3/29 22:15
Oops. Sorry about that. I didn't realise you were like 10hrs drive away ! Anyway I wish someone would save me a trip to the dump and come and get these stock seats .
Posted on: 2007/3/30 19:59
