nissan v6 motor
From Tracy ,Ca
does anyone have any info on installing a v6 in a 1200 also wieght difference. there is a new class this year allows me to install any nissan engine and still wiegh only 1500lbs.
Posted on: 2007/8/18 12:13
Re: nissan v6 motor
From Wagga Wagga
Ask PIGDOG he knows a lot about the V6 conversions.
Posted on: 2007/8/18 13:39
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Re: nissan v6 motor
From Geelong, Vic
i know a bit about installing a commodore v6 into a 1200
but i believe that the nissan v6s, 300zx motor, are a fair bit wider so would be harder to fit
Posted on: 2007/8/18 20:46
Re: nissan v6 motor
From bend oregon
If its any thing like a 510 it will be tight but workable.
Posted on: 2007/8/18 23:31
Re: nissan v6 motor
From Invercargill, New Zealand
A V6 in an auto-x 1200 would mess up your handling severely. Unless you are able to do a set back i.e. cut the fire wall I wouldn't consider it at all. The VG's are tight enough in the 300Z's.
How about using an SR20DE? Would be just as fast and they handle reasonably with a spring change.
Posted on: 2007/8/19 5:20
Re: nissan v6 motor
From The garage, NZ
or ca18de
the smaller bore has got to better for some higher revs?
Posted on: 2007/8/19 7:13
Re: nissan v6 motor
From Castro Valley,CA USA
This is from a long time ago. You can probably email him for more info.
http://www.datsuns.com/projects/eddiet.htm
Posted on: 2007/8/19 7:20
Re: nissan v6 motor
From The garage, NZ
making exhaust for the vg would SUCK in a 1200 but if you got the skill man
Posted on: 2007/8/19 7:24
Re: nissan v6 motor
From Geelong, Vic
cant be any harder than fitting a 383 chev in there
that pic is of the single came vg30, so i think there would be no chance at all of the quad cam version fitting
i wonder if a vh45 would fit in
Posted on: 2007/8/19 8:07
Re: nissan v6 motor
See V6 into 1200 discussion. Why stop with the 3.0, 3.3 or 3.5 V6? Go for the small Nissan V8 from an infiniti or the 5.6 liter from a truck. Or even the twin-turbo VG30DETT...
Ah, but weight. The VG30 fully dressed weighs about 360 pounds, which is pounds/HP ratio of:
A12: 2.45 pounds/HP
VG30: 2.25 pounds/HP
So advantage to VG30... but at twice the weight not so good for rallycrossing? See wiki - Engine weights
Too bad Nissan didn't make a supercharged four, that might work well (low weight/high power, no turbo lag).
Posted on: 2007/8/19 10:40
