lowering blocks?
From QLD
does anyone no were i can get 3 inch lowering blocks for my datsun 1200 ute?
cheers york,
Posted on: 2008/2/4 8:27
Re: lowering blocks?
From sunshine coast QLD
hey m8 i seen some on ebay but they were only 1 1/2 n 2 inch blocks..auto barn might b able 2 get u some. im after a set of 3inch blocks 2..
Robert
Posted on: 2008/2/4 8:38
From QLD
yer i seen them ones, look alright, dont come in three inch though, will try autobarn!
cheers
Posted on: 2008/2/4 8:41
From Perth WA
hope your upping the size of your rims too boys! Even a 2" drop will make the susp drag on the deck if you get a puncture!
Posted on: 2008/2/4 8:44
Chris...
From brisbane
i had a set on my ute when i broughty it. have no idea where he got them from sorry. so u must be able to buy them ..... they look sweet tho... wouldn't be hard to make a set tho i'm sure. just use the 2
" as a template. i know that 2" is the lowest legal block u can use..... if your in qld that is
Posted on: 2008/2/4 8:48
A15 1200 ute, 77 mini -b16a honda vtec project
From QLD
im using 14x7 in dragways hope they fit under the gaurds! , i thought that lowering blocks were illegal in qld?
cheers york.
Posted on: 2008/2/4 10:49
From Canberra
rearrange the leaf pack, only takes an hour, costs nothing (need some tools) and you wont be dragging the lower spring mounts on the ground. May stuff your shocks though over time.
Not a 1200 ute but my 120y went from:
To:
Posted on: 2008/2/4 10:57
From QLD
is that 2 or three inch lowering block on the 120y?
Posted on: 2008/2/4 11:18
From Perth WA
read the post
Posted on: 2008/2/4 11:21
Chris...
From Springwood NSW, Formerly Tas.
its not, he rearranged the leaves in the pack, eg. flip one and reassemble the pack..
if you do this i'd use a shorter shock, like holden/izuzu gemini ones
Posted on: 2008/2/4 11:22
1978 120y Coupe.
