Hitachi su's
From Griffith
I recently purchased some hitachi su's for my old mans ute (720 with a l18) i think i now were everything connects to except for two things , are the two nipples on top of the floats just vacum or are they something else ?
Cheers Alfie
Posted on: 2009/1/21 10:05
Re: Hitachi su's
From Adelaide
The nipples are for the fuel supply to each float bowl.
Posted on: 2009/1/21 10:14
Nissanman - just trying to help...
Re: Hitachi su's
From Griffith
yea i have got them hooked up theres another nippile on the front top of the float
Posted on: 2009/1/21 10:17
Re: Hitachi su's
From Darwin NT
overflow just let it piss out onto the ground
Posted on: 2009/1/21 10:22
current project 4x4 patrol...
Re: Hitachi su's
From Adelaide
You will need to fit a hose to the overflow[s] and route it well below the exhaust to prevent a fire.
Usually, the o/flows are attached to a bracket off the sump flange.
Posted on: 2009/1/21 10:29
Re: Hitachi su's
From Griffith
or could i just run it throught to the emissions pot which in turn will run back to the fuel tank if thats correct
kool always wanted flames coming out of the exhaust good tip haha
Posted on: 2009/1/21 10:35
Re: Hitachi su's
From Adelaide
If you mean the carbon canister, no.
That is only designed to handle fuel VAPOR from the expansion of the fuel in the tank, not raw fuel.
The o/flows are there in the unlikely event that the float valves get stuck or the float chamber overflows.
If they are in good condition, it may never happen.
Posted on: 2009/1/21 10:46
Re: Hitachi su's
From Griffith
ohh ok thanks for your help greemes50
Posted on: 2009/1/21 10:51
