Radiator Leak ?
From Sri Lanka
Hi Guys
Just tell me how to identify Radiator Water leek easily ? I feel the ratio of reducing water is too much in my GX Radiator , I had to fil 2 Liter of water after running 100 KMs.is it too high isnt it ? but there is no major sign of water drops down also .
Thanks
Regards
Sumith
Posted on: 2009/2/23 6:48
Re: Radiator Leak ?
From Perth WA
dont use water, use good quality coolant or your head will corrode in no time.
pull out your oil dipstick and check there is no "cream" sludge on it, that would mean head gasket problem coolant getting into oil.
is the temp going up?
do u have an overflow bottle?
easiest way to tell if radiator is leaking is by looking at it, top it up get it hotand under pressure, and look around the radiator and all hoses for leaks.
Posted on: 2009/2/23 6:56
Re: Radiator Leak ?
From Melbourne, Australia
Buy a preasure tester and attach it to the radiator pump it up to max preasure for system and see if the preasure goes down. If it goes down you have a leak.
Posted on: 2009/2/23 7:22
Re: Radiator Leak ?
From Sri Lanka
Hi 1000Coupe
I dont have a overflow bottle, Usually it is not getting heated, yesterday i was on the way it started increasing accelerator by removing connection cap , then suddenly heater came up ?then i stopped and checked water and filled 2 ltrs , after that heater was normal 40% ,through out another 50KM.
Thanks
Regards
Sumith
Posted on: 2009/2/23 7:26
Re: Radiator Leak ?
From Perth WA
so u r saying it was getting hot and u stopped and opened the cap? If thats the case im thinking at least 1 of the 2 litres u lost was in the radiator and shot out when u opened the cap...?
u should have an overflow/return bottle, that would account for at least 500ml.
Posted on: 2009/2/23 7:53
Re: Radiator Leak ?
From Sri Lanka
Hi 1000Coupe
Do you advise me to connect a Coolant bottle to the Overflow pipe on the top of the Radiator ? below the main radiator Cap
Thanks
Regards
Sumith
Posted on: 2009/2/23 8:35
Re: Radiator Leak ?
From Sri Lanka
Hi Guys
Seems i don't have separate Coolant tank in my Datsun, is it possible for me to add a separate coolant tank and fix it to the radiator , if so can any one explain me clearly please
Thanks
Regards
Sumith
Posted on: 2009/2/23 8:51
Re: Radiator Leak ?
You just add a plastic tank somewhere, anywhere, and run the stock overflow hose into it. That's all
Be aware that after changing the coolant, it will burp out over a couple of days and need topping up, even a couple of liters. This is normal, and does not indicate a leak.
Posted on: 2009/2/24 2:27
Re: Radiator Leak ?
From Brisbane, Queensland
Do you have the right radiator cap on it, and not a recovery tank style cap on it.
Posted on: 2009/2/24 5:31
Until Morale improves the beatings will continue
Re: Radiator Leak ?
From Sri Lanka
Hi Guys,
I saw the Water Line which goes in to the AC unit has been removed from the connection and bended and winded to avoid water leak, will that be a reason to reduce my radiator water reduction ?
Thanks
Regards
Sumith
Posted on: 2009/2/27 8:49
