Head Gasket Gone ......... ?
From Sri Lanka
Hi Guys
I saw suddenly My Engine Oil has become White color , seems Head Gasket Gone isn't it guys
i am wondering how it happened suddenly by 2 days, usually i check my engine oil before any run
after 2 days that was white when i checked .. ??
Thanks
Regards
Sumith
Posted on: 2009/3/2 7:29
Re: Head Gasket Gone ......... ?
From Melbourne, Australia
on the dipstick or in rocker cover or both
most likely is head gasket
have seen small amounts of white from condensation
drop the oil out and see how much water
if a chunk of gasket breaks loose it could turn bad quite quickly
Posted on: 2009/3/2 7:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Yes. A "blown head gasket" usually happens all at once.
To prevent if from re-occurring:
* Clean block face and head face thoroughly, and chase off all oil residue
* Clean head bolt holes thoroughly
* Check head and block faces for straightness
* Use a quality gasket (e.g. Japan-made)
* Tighten in three stages, in the spiral pattern, with a torque wrench
* If the gasket is not the no-torque kind, be sure to re-torque 100 miles after installing. And then re-torque yearly.
Posted on: 2009/3/2 7:40
From Sri Lanka
Hi ddgonzal
Is the A12 and A12 GX Head gasket Same or different ? what is the price of Japan Head Gasket there ? here i have got 1 for 5 u$ might be a non Japanese product
Thanks
Regards
Sumith
Posted on: 2009/3/2 8:08
are you saying this happened after building the motor 2 days ago?
a12 and a12gx head gaskets are same, it is possible to put them in upside down though
if this happened two days after engine build there was obviously a problem during assembely
possibly block surface or head surface is not flat also
Posted on: 2009/3/2 8:10
1200 Coupe Rallycar
A12 engine and A12 single-carb engine in Datsun B210 GX use the same gasket.
If you wish to gain more compression, you may use the A12 GX gasket, which is thinner.
What brand is the gasket you are looking at? They are about $20 USD here normal price.
Posted on: 2009/3/2 8:11
From Sri Lanka
Hi 1200rallycar
No No not after 2 days of fitting a new gasket, as my daily routine i check my engine oil, i did not travel for 2 days and checked suddenly realized oil has become white
Thanks
Regards
Sumith
Posted on: 2009/3/2 8:34
From Sri Lanka
Hi ddgonzal
Here i dont think i may find GX Head Gasket, the one available also lower brand 1 , that is why it is so cheaper , how long will it remain ? and a original 1 ?
Thanks
Regards
Sumith
Posted on: 2009/3/2 8:40
An original-equipment Nissan head gasket for A12 engine will typically last 10 years or more. Mine is 35+ years old, still going strong.
How long will cheap one remain? You tell us, how long did it last?
Posted on: 2009/3/3 0:54
From Perth WA
hi sumith
remember when u said u were losing water about a week ago i asked if u had any "cream' on the dipstick. the water would have been getting into the oil even then.
This happens easily on these engines if u use water instead of good quality coolant, corrosion around water channels. u will probably find corrosion around the water channels and this needing welding or even a new head, just a gasket wont last.
Posted on: 2009/3/3 1:28
