(1) 2 3 »
Head studs?
From Gawler, Sth Aust
Hey.
Head studs. WTF!
What are the benefits vs cost?
Is there any need in a street application?
Cheers
Posted on: 2009/10/14 2:16
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
Re: Head studs?
From pooraka,,adelaide
iv heard they are stronger and the bolts dont stretch thats all i kno...?
Posted on: 2009/10/14 3:05
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Re: Head studs?
From mandurah
and they are harder to strip the thread so you can get them tighter
Posted on: 2009/10/14 3:44
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: Head studs?
Absolutely no benefit. Yes, they are stronger than bolts so can be torqued more tightly. But stock head bolts are strong and don't cause any problems.
The studs are called for in high boost turbo street engines.
Posted on: 2009/10/14 6:37
Re: Head studs?
From Geelong, Vic
they arent really that expensive, i got a set for the CA for $200 delivered compared to the stock torque to yeild bolts being $80 non genuine
the advantage of them is that because the stud/bolt is harder than the block it is possible to damage the thread when doing that up as not all the thread is actually being used at the start
whereas with a stud all the thread on the stud in in the block from the moment you start to tighten the nuts on the stud
Posted on: 2009/10/14 7:00
Re: Head studs?
My comments were intended for A-series engine, as found in Datsun 1200. These engines are not known to strip the threads on stock head bolts.
CA engine may be different. Certainly torque-to-yield bolts cannot be re-used, so in that case you do have to buy something (bolts or ARP studs) when you change the head gaskets.
Thank goodness the A Engine does not use TTY bolts. An original set will last indefinitely.
Posted on: 2009/10/14 7:21
Re: Head studs?
You don't think a high comp setup would require these studs?
Posted on: 2009/10/14 7:34
72 B110 A14
06 380 VRX
Re: Head studs?
Providing that you don't skimp on a quality head gasket then there is no reason why a good set of standard head bolts won't do a good job. I would use them on a street engine up to 12:1 compression or a turbo engine up to 10 psi.
Posted on: 2009/10/14 7:43
Re: Head studs?
Oh cool. I didn't imagine I would be up near 11:1 let alone 12:1. I'm glad that's an extra I can cross off the rebuild list.
Cheers peoples.
Posted on: 2009/10/14 8:49
72 B110 A14
06 380 VRX
Re: Head studs?
I run 12.5:1 compression ratio and stick to the Number '13' studs.
These were featured on GX engines and the economy big blocks (A14, A15) and maybe others.
These are higher tensile bolts that suffice for the job and suit my budget.
The conrod bolts however, are ARP bolts. The stock con-rod bolts I would be weary of, but not overly paranoid about in a mild street engine.
Just check you don't have any '13' bolts as they are more common than I had ever realised.
Posted on: 2009/10/14 9:26
(1) 2 3 »
