Silvia brake setup ? model of strut.
From sydney
I am thinking of doing a silvia brake setup , just want to know how do i tell what model struts i am running & did 1979 1200 utes come with front disc brakes.
Also where can i get the brackets made up from ? or can you buy them off the shelf.
Thanks.
Posted on: 2010/1/24 11:04
Re: Silvia brake setup ? model of strut.
From Melbourne AUS
im assuming you mean the caliper brackets and if so you can get them from kev rowley or they even pop up on ebay sometimes.
not sure that late utes had discs, could be coupe discs or 120y which is good cos you can use either for the s13 upgrade.
Posted on: 2010/1/24 11:20
1973 B110 A12
From Tamworth , NSW
wouldnt think the 79 ute came with discs.
my old ute was an 81 or 82 and it had drums all round.
Posted on: 2010/1/24 11:25
From Geelong, Vic
1200 utes all had drums, only coupes got discs
Posted on: 2010/1/24 11:39
From northern 'burbs adelaide
you need some of the brackets i make and 120y struts. the hubs also need machining about 2-3mm off of their diameter
Posted on: 2010/1/24 11:56
From sydney
Yeah sorry the caliper brackets.. ok is there any way i can tell the difference between the 1200 coupe and 120y struts or are they the same ?
How much for the brackets aidaniel ?
Posted on: 2010/1/24 12:09
PROJECT:DATSUN sunny sedan CA18det
$40+$15postage ... i dont know the difference between the struts
Posted on: 2010/1/24 12:13
From sydney
Have you got a complete set of struts with the conversion done already that you want to sell =)
Posted on: 2010/1/24 13:30
From cranbourne, vic
there the same dimensions realy. only visual difference you will see is that the late 120y (pbr spec) struts are missing the bracket for the brake line.
Posted on: 2010/1/24 14:48
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From sydney
Ok sweet , looks like i have the struts do the conversion then .
Posted on: 2010/1/24 20:57
