a15
From Goulburn NSW
How much hp could you expect to get out of a turboed fuel injected a15
Posted on: 2010/11/18 7:43
Re: a15
From Ballarat Victoria
About 175 to 225 reliable hp from a stock A15 with bolt on bits. add up to 100 more for a race prepped engine. The $$$$ and knowledge are the usually the limiting factors.
Posted on: 2010/11/18 7:56
Re: a15
From mandurah
pfft i dont think people would bother with CA and sr if you could get that power out of an A series reliably
Posted on: 2010/11/18 9:07
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: a15
From sydney.nsw
sh*t ,what would it do with the bottle ,another 100. pour a15.it could be messy.who needs a v8. 225+100+100=I want one. 'WHERE DO YOU GET IT '
Posted on: 2010/11/18 9:17
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: a15
These engines seem to respond well to a turbo.
Surely you have tried Ernie.
My STOCK A12 makes 180HP with bolt ons and 190kpa. An A15 could make the same power with a lower MAP.
Posted on: 2010/11/18 9:46
Re: a15
From sydney.nsw
No offence; but I would take my hat off and like to shake there hand with a pat on the back, for the person with 300+hp from a A15 DATO Engine (maybe one day, ive still got a few years let in me i think hopefully). cheers
Posted on: 2010/11/18 11:01
Re: a15
The figures i mentioned are not hypothetical, Its been done. I think it was over 300 on a Dyno Dynamics. You could probably add another 30 or so on an engine dyno. Someone will post a link as i dont know how.
Another way to look at it is this. A good race NA A15 could make 150HP. Now double the manifold pressure. That same engine would make about 270Hp and thats only running 15 PSI.
I will add that i was being a bit optomistic saying 225Hp on a stock motor and have reliability. But i`ll stand by the other figures.
Topgear made 97KW ATW (about 160 at the flywheel)with a draw through carb, no intercooling and pump gas on an A12 and 18psi. Not that i would think it would be very reliable without intercooling.
My A12 made 150HP ATW (about 170 at the flywheel) with only 14psi. (old engine with new cast rings only) I think an A15 should be able to do it easier.
Ernie, I think someone like yourself could make 300HP+ if you put your mind to it.
Posted on: 2010/11/18 12:14
Re: a15
Found the Youtube Vid of 320HP ATW A series.
http://www.youtube.com/watch?v=IXTn_rdtbhQ
Some good Engine building and tuning there!
Posted on: 2010/11/23 1:44
Re: a15
From sydney.nsw
Thats impressive,well done to them guys.(maybe one day for me)that gives me more motivation to do something.cheers
Posted on: 2010/11/23 2:26
Re: a15
Ummmmm, I hate to split hairs here but your STOCK [non GX] Datsun A12 engine produces about 68 HP.
If it produces more than this, then clearly it isn't stock.
If you are running 190,000 pascals of boost then you have a blower or turbo & no A12 ever came stock with one of these.
Your BLOWN A12 therefore produces whatever you said, but not your stock one.
Posted on: 2010/11/23 13:47
Love your Datsun.
Treat it well.
