S15 High flowed Turbo - SR20DET - Standard ECU OK?
Not too shy to talk
Hi Guys,
Just wanted to know if an ecu upgrade is required if you are using a S15 High flowed turbo on a S13 SR20DET with standard injectors, high flow pump, ext waste gate, FMIC, 3" Exhaust system, pod filter?
Thanks.
Posted on: 2011/6/7 21:02
Re: S15 High flowed Turbo - SR20DET - Standard ECU OK?
From Melbourne Vic
Not necessarily. being able to tune it for more boost might be handy though. Look into nistune for your standard ecu, it will do all a cheap aftermarket ecu will and keep good cold start, cruise etc
Posted on: 2011/6/7 23:01
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
