gbox
From sydney
how do i get the rear seal out of the a56 gearbox so it can be replaced???
Posted on: 2012/10/24 9:15
Re: gbox
The shield is part of the seal. Does it need replacing or are you doing it because you can? Because the orig ones are the best. Get a genuine Nissan on if possible. They are worth the extra few dollars.
Posted on: 2012/10/24 10:23
Re: gbox
From sydney
The seal is actually leaking so it definently needs to be changed, soo you can't get the seal out???
Posted on: 2012/10/26 1:08
Re: gbox
From Trinidad and tobago
Just put the box upside and tap around the sheild evenly untill it comes out.
Posted on: 2012/10/26 1:33
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: gbox
Posted on: 2012/10/26 1:44
Re: gbox
Not too shy to talk
From brisbane australia
I recently replaced this seal on my box with a Nissan genuine one but its still leaking heaps, someone told me there is also a bush that may be worn causing the leak? Is that correct?
Posted on: 2012/10/29 12:09
Re: gbox
Yes, the tailshaft slip-yoke is held in place by a (non-replaceable) bushing. If the yoke flops around, replace the transmission tail housing.
Another cause is a groove in the face of the slip-yoke.
Posted on: 2012/10/29 17:33
Re: gbox
Not too shy to talk
Thanks for the info, that sounds like a big job, why is the bush not replaceable? I don't think the yoke on the driveshaft is worn.
Posted on: 2012/10/29 21:19
Re: gbox
You'd have to ask Nissan why.
Posted on: 2012/10/29 21:51
Re: gbox
Not too shy to talk
Haha sweet,
Anyone selling a cheap gearbox out there? One without oil leaks that is
Posted on: 2012/10/30 2:21
