Browsing this Thread:
1 Anonymous Users
A14 Head to A12 block |
Hi :Can anyone confirm that an A14 head will bolt straight onto an A12 block
Posted on: 2012/11/20 14:35
Re: A14 Head to A12 block |
From Malaysia
no problem at all. they will bolt straight
Posted on: 2012/11/20 16:20
From Malaysia
Posted on: 2012/11/20 16:25
From St. Louis, MO USA
If you have the early A12 block 1971-1973 with the separate oil feed hole away from the center head stud, you will have to have a matching oil feed in the head. It is a simple (but mandatory) task to make sure oil feeds from block to head.
In past we have drilled the holes and then tapped/plugged the access way. It is very easy if the boss already exists on the head.
We have also run AN-3 oil feed lines from the main block oil galley right up to the head. I have this on one engine. It is a little bit of a pain if you are switching heads and blocks (like at the racetrack), but no problem if that head will stay with that block.
Peter
Posted on: 2012/11/20 16:59
Thanks guys, the info is a great help
Posted on: 2012/11/21 2:54
