restoring 1200 coupe dash / upgrading gauges / interior shifter boot
From perth airport
hello datsun fans
ill be restoring my coupe dash , i have purchased the following new dash pad , glove box and dash under tray from japan ,
i may have to reuse the dash facia .
the car is running a sr20det but i want the interior looking standard , and assume the speedometer and tachometer will need changing
if you can recommend gauges that fit nice and maintain a standard look im all ears :D
also running madddat tunnel i assume standard carpet wont fit ? but main thing is maintaining an era correct gear shift boot :? again any ideas ?
Posted on: 2015/3/3 5:06
perth airport parking
Datsun 1200 ute A14
Re: restoring 1200 coupe dash / upgrading gauges / interior shifter boot
From MOOROODUC. Victoria
Check out my Ute build thread. I integrated the S13 instruments using the old dash facia cutting out the speedo
Posted on: 2015/3/3 5:30
From perth airport
cheers man but thats not the style im going for ,
Posted on: 2015/3/3 6:45
Datsun 1200 ute A14
