Charging Issue on my b210
From Sri Lanka
Hi Guys
I have a problem in my b210 when on idle suddenly i get a click noise from the voltage regulator and immediately charge
bulb comes on , What Would be the Issue is it alternator ? or Regulator ?
When Higher Rpm No sign of anything like that
thanks
regards
sumith
Posted on: 2016/8/3 8:50
Re: Charging Issue on my b210
It is usually a problem with the Regulator. The job of the regulator is 1) to turn alternator on/off rapidly to average about 13.5 V (because alternator on = 17V or more) and 2) to turn the Dash Lamp on when alternator is not charging (which sometimes makes an audible click)
To test the alternator use simple jumper wires (see Basic Testing)
Posted on: 2016/8/3 9:01
From Sri Lanka
Hi Guys
OK Done it was a problem with my alternator , i have fitted a alternator with diode plate it was a short diode plate, fixed the issue it is fine now
thanks
regards
sumith
Posted on: 2016/8/11 9:19
Thanks for letting us know -- a click can be caused by a shorted diode. By testing the alternator as above, the problem can be determined to be not caused by the regulator
Posted on: 2016/8/11 9:57
From Biloela, Sunshine State
And again I learn something new every time I log in. Love this Club
Posted on: 2016/8/13 6:20
