do I need an oil catch can?
From brisbane
Is it advisable to install one on an A series motor or can I install a small filter onto the tappet cover instead?
Thanks Matty
Posted on: 2003/7/1 14:03
Re: do I need an oil catch can?
From Sydney, Australia
It depends if you race the car or not.
Generally, I don't think you need a catch can.. except on Turbo'd cars, or full-on race cars, like the ones that used to do 13,000rpm down conrod straight with the A12.
I've never seen oil in the filter unit of a standard A12. This means that no oil comes out of the valve cover breather. So I'd try my best to adhere to environmental laws, and I'd pipe the valve cover breather back to the airbox. If you run webers with socks, instead of a box, then a small filter is fine.
Chris
Posted on: 2003/7/1 15:16
A small filter is fine and shouldn't affect emissions output (though it might be against the emissions law where you are). Just make sure your PCV valve is connected
If your street engine is heavily worn, you'll get oil in the filter but otherwise it should be OK.
There was some talk about using a hose with a bend, so that any oil thrown up by the rocker assembly would hit the hose and run back down ... just try it and see what happens.
Posted on: 2003/7/2 3:22
From Christchurch New Zealand
i think if your motor is screaming at 13,000rpm you probally will see a conrod anway
Posted on: 2003/7/2 5:31
"If your not living on the edge your taking up too much space" Rod Millen
Quite a regular
If you decide to race it, it is not a question if you should or should not...you have to.
Posted on: 2003/7/3 9:50
Boston Racing
