Extractors 1000
From Bathurst
Does anybody know what type of extractors i need to use for the 1000? Apparently they don't make them anymore. IS the A12 compatible?
Posted on: 2003/7/13 10:11
The beauty of it is, no one sees it coming
Re: Extractors 1000
From sydney australia
try liverpool exhaust here in sydney,they made some mandrel bent extractors for a friend to suit an a15 into a 1000.the problem is the steering idler arm is in the way of stock extractors.try them on 02-9602-3111 or 02-9602-3152.
Posted on: 2003/7/13 10:19
Re: Extractors 1000
From sutho shire
defenetly liverpool they are very good i recomend them 2! cheap 2!
Posted on: 2003/7/13 10:41
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: Extractors 1000
From Perth
For my 1000 coupe with A12 in it I just used 1200 coupe ones. I didn't have any steering clearance probs. Just engine mount.
I had to beat the daylights out of the passengers side mount to make room for the pipes.
Other than that all good. 2.25" systems and it used to sound great.
My brother just fitted a A15 to his 1000 ute and used my spare set of extractors (different brand).....same engine mount issue but thats all.
Posted on: 2003/7/13 12:50
