AE86 LSD INTO H165 DIFF
From Albury
Hi guys
Has any one actually done this swap .There is info on wiki but it all seems to be hearsay.I am interested in this conversion or any others that you may know of.
Thanks
Bob
Posted on: 2009/2/28 5:56
Re: AE86 LSD INTO H165 DIFF
From Gold Coast, Australia
im curious myself
Posted on: 2009/2/28 6:15
From Perth
Hi, i have looked into it in depth and have run TRD LSD setups in many different ways.
I do not like the conversion as you would need to machine down the bearing carriers so much to fit the Datsun bearing that there would be not enough metal left.
A better way is to get Datsun axel tubes welded to a sprinter diff centre housing. you would run a full TRD/Sprinter centre and gear ratios but still use H165 axels. getting the housing changed is also a easer job than modifying the centre.
I have a TRD LSD centre for sale to suit H165 axels for $600 or $700 with carrier and I think 4.3:1 ratio crown wheel/pinion (needs assembly). I even have an old sprinter housing i could chuck in for free.
Posted on: 2009/2/28 6:25
On the subject but an alternative anyone know what a billet alloy housing would cost for a BW rear end on pintaras and skylines or even a hilux rear end?
Posted on: 2009/2/28 13:12
Quite a regular
From Melbourne, Australia
i seem to remember from when i looked at this conversion that the H165 & sprinter use bearings with the same OD cup, therefore there is no need to machine the LSD to suit the Datsun bearings. just use sprinter carrier bearings.
from my recollection, the only machining was a couple mm on the crownwheel diameter to suit the Datsun crownwheel, and some sleeves needed to be made up to suit the datsun crownwheel bolts.
i never ended up doing the conversion (welding was cheaper....), but have been thinking about doing it again recently. just need to get hold of a sprinter diff center to confirm my measurements.
stu
Posted on: 2009/3/1 8:47
From Perth
i have both diffs and the TRD bearings are much larger.
here is a pic of the TRD centre after is has been modified for datsun bearings, you can see how little metal is left after machining
Posted on: 2009/3/1 8:56
Quite a regular
hmmm, my mistake. looks like my memory is starting to fail me :)
ahh, so you end up machining the trd bearing journal down to datsun size. bugger, there goes all the added strength the toyota center offered.
stu
Posted on: 2009/3/6 7:28
gidday Matt do you still have that set up for sale as I require a LSD for my coupe here in chch 021 206 9166
Posted on: 2010/5/23 0:25
