Body Side Panels
(Redirected from Quarter Panel)
Category: Body
Side panels of the Body.
4-door Sedan
103-0D.jpg 8075.jpgAlbum 8075
60 Front Pillar (A-pillar)
   Front Pillar Lower Reinforcement 8910-
   Window Corner Patch 8504-
62 Windshield Pillar, inner (A-pillar)
64 Dash side (Front Pillar Lower Bracket)
65 Roof Side Rail, outer
67 Roof Side Rail, inner
   Roof Side Rail, rear (Van)
69 Sill Panel, outer
   Sill Panel, inner - See Floor side panel
71 Center Pillar, outer
   Center Pillar, inner
   Center Pillar, lock (Coupe)
73 Rear Pillar, inner (4-door sedan)
   Rear Pillar, outer
   Rear Pillar, lower outer
   Body Side inner panel (2-door sedan)
   Body Side outer panel (see #Quarter Panel)
74 Rear Wheel House, outer
76 Rear Wheel House, inner
78 Shock mounting Bracket
79 Rear Sill Closing Plate
81 Lower Trunk floor side panel
20790.jpgAlbum 20790 20788.jpgAlbum 20788 174_65b2c94e173b4.jpgPost 498220 174_65b2c957c896d.jpgPost 498220 174_65b2c96095d39.jpgPost 498220 174_65b2c96a45906.jpgPost 498220
2-door Sedan - differs mainly in using Rear Panels instead of rear Pillar.
Coupe
76412-H1800.jpg 17736.jpgAlbum 17736 21413.jpgAlbum 21413
Sedan Rear Wheel House
26197.jpgAlbum 26197
Rear Wheel Arch
The wheelhousing is comprised of inner and out arches.
Rear outer arch (4-door sedan)
20475.jpgAlbum 20475
On four-door sedan, the door indents intrude on the arches -- unlike two door models (including ute, coupe and 2-dr sedan). With large tires or wheels offset too close to the outside of the car it can rub against this indentation when going over bumps, especially with a lowered sedan.
Here is the place most likely to rub -- but on the inside:
174_568735b0328b6.jpgUpload click to view 174_5687340dc681f.jpgUpload click to view
To mitigate this rubbing, use a hammer to modify the sheet metal. Oan had 225 rear tyres on his sedan, and at first they rubbed on the rear arch. He used a hammer to mod the inner arch. It all depends on the wheel offset - even 185s will rub with the wrong wheel offset, but no rubbing at all with other offsets.
Take a ball peen hammer and start at the rear end of the bump where it is small. With lots of hammering and some finesse you can invert the raised area and gain quite a bit of tire room. Just takes time and makes lots of noise.
174_5687341aa3e77.jpgUpload click to view
Sill
Sill is the lower plate of the door opening. Also known as the rocker panel. Sills differ for each body style. It also has the front Jack locating notch stamped in it. Sedan sills additionally have a notch for the rear Jack location.
LONG SILLS - goes back to wheel housing
* H10 4-door Sedan, 4-door Van
* H12 2-door Sedan, 2-door Van
MEDIUM LENGTH - about 6" shorter than Van/Sedan
* H18 Coupe
SHORT SILL - 150mm shorter than Coupe
* G12 Truck > G10 to 8503
174_56120c66a7c90.jpgUpload click to view
Ute sills
2-door Sedan sills
Coupe - 76412-H1800 < G6412-H1800 (pre-drilled for the stainless Moulding)
76412-H1800a.jpg 76412-H1800b.jpg 76412-H1800c.jpg 76412-H1800d.jpg 76412-H1800e.jpg 76412-H1800f.jpg 76412-H1800g.jpg 76412-H1800h.jpg 76412-H1800i.jpg 76412-H1800j.jpg 76412-H1800k.jpg
Datsun 1000 (B10) sill 4-door RH
New Sills
Genunine Nissan
Aftermarket reproduction
Forward end of sill butts against the A-pillar:
IMG_5892.jpg 9366.jpgAlbum 9366
Sill Repair
10245.jpgAlbum 10245 10244.jpgAlbum 10244 10232.jpgAlbum 10232
POST Ed's 81 Datsun 1200 ute build
Make your own sheet metal brake:
POST 3J Improved Production coupe
POST Rob's CA18DET 1200 UTE - Lower end of A-piller
POST Rob's - sill slips into this and is then spot-welded
POST Rob's
G6411-G1200 Sunny Truck
Quarter Panel
Sedan quarter panel, or as Datsun calls it "rear fender"
19072.jpgAlbum 19072 19073.jpgAlbum 19073 15733.jpgAlbum 15733
78101-H1900 ASSY-FENDER REAR LH 2DR SEDAN USA
78101-H1200 ASS'Y-FENDER,rear (L.H.) 2 door JAPAN
      H1000 (from '72-3)
78101-H1055 ASS'Y-FENDER,rear (L.H.) 4 door JAPAN
78101-H2825 PANEL ASS'Y-fender, rear (L.H.) PB110
Sedan Airbox (attaches to inside of upper quarter)
H10 4-door sedan
H12 2-door sedan
Coupe quarter panel
17732.jpgAlbum 17732 17724.jpgAlbum 17724
Coupe quarter panel
78111-H1955 ASSY-FENDER REAR LH COUPE 78111-H1905 <> 78111-H1955 USA
78111-H1800 ASS'Y-FENDER,rear <> 78111-H1850 < 78111-H1851 JAPAN
Van quarter panel
78101-H1450 ASS'Y-FENDER, rear (L.H.) < 78101-H1455 JAPAN
Truck Rear Side
  • Long Body has 5 hooks per side
  • Short Body has 4 hooks per side
  • Red parts differ Long Body versus Short Body
23216.jpgAlbum 23216
76304-G1025 PANEL ASS'Y-body side outer (R.H.)
76305-G1025 PANEL ASS'Y-body side outer (L.H.)
1 76306-G1050 PANEL ASS'Y-body side outer rear (R.H.) with gas filler lid
3326.jpgAlbum 3326
2 76307-G1050 PANEL ASS'Y-body side outer rear (L.H.)
3 76310-G1050 PANEL ASS'Y-body side outer rear end (R.H.)
3 76311-G1050 PANEL ASS'Y-body side outer rear end (L.H.)
4 90510-G1000 HOOK ASS'Y-rear gate (R.H.)
4 90511-G1000 HOOK ASS'Y-rear gate (L.H.)
5 75310-G1000 REINFORCEMENT ASS'Y-anchorage upper (R.H.)
5 75311-G1000 REINFORCEMENT ASS'Y-anchorage upper (L.H.)
6 76500-G1000 PILLAR ASS'Y-center (R.H.)
6 76501-G1000 PILLAR ASS'Y-center (L.H.)
7 76308-G1050 PANEL ASS'Y-body side outer upper (R.H.)
  * superceded 76308 G1000
8 76309-G1050 PANEL ASS'Y-body side outer upper (L.H.)
  * superceded 76309-G1000
9 76320-G1027 PANEL ASS'Y-body side inner rear (R.H.)
10 76321-G1026 PANEL ASS'Y-body side inner rear (L.H.)
   * superceded 76321 G1025 superceded 76320-G1026
   ** replaced 76320-G1025
11 93332-G1000 HOOK-rope (8)
12 79200-G1000 PANEL ASS'Y-back inside (R.H.)
12 79201-G1000 PANEL ASS'Y-back inside (L.H.)
13 76907-G1000 COVER-body side (R.H.) [3-bar]
13 76908-G1000 COVER-body side (L.H.) [3-bar]
11867.jpgAlbum click to view 13595.jpgAlbum click to view
* 14 96706-G1000 GROMMET-screw (12 per side)
* 15 08530-51612 SCREW (12 per side)
Long Body - same as above except:
76304-G1425 PANEL ASS'Y-body side outer (R.H.) LB
76305-G1425 PANEL ASS'Y-body side outer (L.H.) LB
1 76306-G1450 PANEL ASS'Y-body side outer rear (R.H.)
  * includes gas filler lid
2 76307-G1400 PANEL ASS'Y-body side outer rear (L.H.)
9 76320-G1425 PANEL ASS'Y-body side inner rear (R.H.)
10 76321-G1425 PANEL ASS'Y-body side inner rear (L.H.)
11 93332-G1000 HOOK-rope (10)
13 76907-G1400 COVER-body side (R.H.) [4-bar]
13 76908-G1400 COVER-body side (L.H.) [4-bar]
Truck Rear Quarters
X-RAY
3330.jpgAlbum 3330 6240.jpgAlbum 6240 6241.jpgAlbum 6241 9197.jpgAlbum 9197 10879.jpgAlbum 10879 11082.jpgAlbum 11082 11618.jpgAlbum 11618 11619.jpgAlbum 11619 11621.jpgAlbum 11621 11735.jpgAlbum 11735 14180.jpgAlbum 14180 14468.jpgAlbum 14468 14820.jpgAlbum 14820 15017.jpgAlbum 15017
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Body_Side_Panels"
This page has been accessed 22,608 times. This page was last modified 19:42, 9 February 2024. Content is available under Datsun 1200 Club.
