For many parts you don't need a gasket, you can use just RTV for a leak-proof seal. But RTV is over easy to misuse, so follow the directions to the letter. Engine failure has resulted from improper RTV application.
Instead of a gasket, use RTV silicone sealer "gasket maker". Just be careful not to use too much and to follow the directions (e.g. let it partially set up before assembly)
CAUTION: Do not use on the oil pump
Nissan uses RTV, for example on KA oil pans. RTV works good if you are careful and use it thinly and evenly. But it is very easy to make a mess with it.
Do not use a gasket AND RTV.
Nissan 999MP-1217FPP Liquid Gasket Makerᴳ (THREEBOND 1217F)
Nissan also specified Permatex Ultra Grey in some markets
Kinds
- Permatex Ultra Grey (expensive, but does everything). Specified by Nissan
- Permatex have "Gear Oil RTV Sealant" Quote: "Because gear oil has friction modifiers that break down normal RTV and cause leaking, this specialty silicone has been tested to OEM specifications to ensure complete sealing."
- Permatex also have Ultra Black RTV Silicone which is designed for "differential covers".
- Oxygen Sensor Safe RTV does not have the outgassing fumes of normal RTV
Applications
RTV can be used for (among other things):
- Timing Cover
- Water Pump
- oil pan corners
- Bush fix/road fix
- Thermostat Housing
- plugging manifold Water Ports
Usage
Follow the directions to the letter on the package.
1. Remove all trace of prior gasket 2. Apply a thin but consistent amount of RTV 3. Let "set" to tack before mating the parts 4. bolt it on — but not too tight
RTV gasket should have very little squeeze out. You don't want that stuff inside the engine, but only on the sealing surfaces. Excess amounts will squeeze out, and may clog oil or water passages.
Get the gaskets surfaces clean and flat
Use thin bead of RTV, and let it tack-up before installing
After mating of the parts, only a minimal amount of RTV will bulge out
