Water Ports
From Datsun 1200 Club
Categories: Engine Mechanical | Cooling System
Coolant passages are below the intake ports in some A-series Cylinder Heads. They can be large holes or small holes.
Water ports keep the bottom of the manifold plenum at a hotspot for complete air/fuel burning, even at low throttle.
  • A12GX has Four Large coolant holes, one beneath each inlet
    4441.jpgAlbum 4441
  • Other heads have either no coolant holes, small ones, or a mix:
    4444.jpgAlbum 4444
  • Standard Datsun 1200 heads have no coolant holes on the intake side.
Water outlet
14473.jpgAlbum 14473 11093.jpgAlbum 11093
A-series heads will interchange with either dry or wet Intake Manifold with the following caveats:
  • If the intake doesn't have coolant passages, tap the head's coolant ports and install plugs
    4444.jpgAlbum 4444
  • If the intake has coolant ports, but the head doesn't, it may bolt on without modifications. Idle and low-throttle running may suffer due to insufficient heat. However, heavy throttle operation should be OK.
    5758.jpgAlbum 5758
Port Plugging
Two methods
* drill, tap and fit plugs
or
* use RTV sealant plugs
Discussion: H89 water gallery pluging?
Screw-in Plugs
Directions for plugging the cylinder head with blind plugs:
4440.jpgAlbum 4440
Nissan plug parts
99996-H1149 STUD & PLUG KIT
You can buy grub screws in many places, most auto shops for example. Measure the hole, tap the mext mm up and screw in a plug. A bit of form-a-gasket, copper seal or anti-seize on the threads will help prevent corrosion and seizing.
Nissan Competition head 99996-H1165
For the heads with smaller water galleries (H75, H89 etc) use stainless steel grub screws M5x0.8 by 5mm long. Use red loctite to seal and stop any movement.
Make sure the end of the screw is below the sealing surface on the head, and file the surface flat if there's any burrs from drilling/tapping the holes.
RTV Plugs
If your dry inlet manifold comes down far enough to cover the holes, you can use silicone sealer like this:
23478.jpgAlbum 23478
This is an easy way to seal it, but coolant may leak when you change the manifold. Just re-seal it each time. By contrast, blind plugs are a one-time semi-permanent solution.
Used RTV silicone sealer. After fitting the intake/exhaust gasket, before fitting the intake manifold, press some RTV into the water ports, the put a button of goo over it. Let it tack up slightly before fitting the intake.
4848.jpgAlbum 4848
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Water_Ports"
This page has been accessed 13,171 times. This page was last modified 02:17, 12 July 2020. Content is available under Datsun 1200 Club.
