Coolant
From Datsun 1200 Club
Category: Cooling System
The Radiator Coolant keeps the engine from overheating while protecting it from rust and corrosion. It also prevents it from freezing, so is sometimes called anti-freeze (antifreeze).
Straight water can be used in a pinch, but is subject to rust and to freezing, and water which has not been demineralised can cause particle build up in the cooling system.
Daily Care
  • Radiator coolant
  • CAUTION: Do not check at gas-station, but only when radiator is cool to the touch
  • Remove cap and if fluid level is more than 1 inch below opening, add Coolant. Do not fill to the top.
Fill the radiator with demineralised water in a 50/50 mix of coolant/antifreeze.
If you live in freezing areas, check the coolant container for instructions (which may require a 30/70 mix in very cold areas).
20395.jpgAlbum 20395
When topping up the system, do not use plain water. Top up the system using coolant mixed in the correct ratio.
Plain water can be used in an emergency, BUT once home and the problem/s have been rectified, the system should be drained and refilled with properly mixed coolant.
  • Coolant capacity: 4.9 liter (5-3/16 US quart, 4-5/16 imperial qt)
Many of these brands listed below have changed names.
Antifreeze/Coolant for radiator
1972 USA Owners manual (Page 23 ... ):
Recommended Lubricants
Antifreeze/Coolant Specifications
Recommended:
  • Producing: Antifreeze coolant L.L.C. (Nissan "Long Life Coolant")
  • Shell Shellzone
Acceptable:
  • Chevron Atlas Perma Guard antifreeze
  • ESSO Long Life Coolant
  • ESSO Atlas Long Life Coolant RAD
  • Mobile Permazone
  • Sunoco Permanent Type
  • Texaco Antifreeze Coolant
  • Texaco Startex Antifreeze Coolant
Any modern antifreeze/coolant that is compatible with aluminium parts should be acceptable. The Datsun 1200 uses an aluminium head and water pump.
Failure to use coolant with anti-corrosive properties or failing to replace coolant regularly will result in rapid degradation of the aluminium parts.
Check coolant condition using a tester for this purpose, or drain and replace it every 2 years with new, properly mixed coolant, regardless of the manufacturer's claims of years/mileage.
50/50 coolant concentrate and DEMINERALISED water.
Failure to use demineralised water can result in scale build-up in the system. This creates an insulating barrier which reduces the transfer of heat from engine parts to coolant, and coolant to radiator. If the buildup is severe enough, the tubes in the radiator and heater cores will be completely blocked and coolant will not flow.
Using a 'lean' mixture of concentrate-water will not protect from corrosion.
Using too 'rich' of a mixture is expensive and can cause degradation of hoses and other parts, ineffective heat transfer, and ineffective mixture of protective ingredients throughout the system.
Replacement
The Maintenance Schedule calls for replacement of the engine coolant every two years. Use long-life coolant.
When draining, remove the engine block drain plug too.
When removing this plug, be sure to use a tight fitting 6-point socket/spanner. Failure to do so will result in stripping the corners off the head of the plug. These were manufactured from a very soft steel and are very easy to round off if the incorrect tools are used. You were warned...
Once removed, most of the time you will find it won't drain because decades of rust and scale and crud builds up in this low flow area of the coolant system. Use an old drill bit to hand-drill your way through the crud until it starts to drain, and then stick a running garden hose in the radiator with the radiator hoses connected. Use some thick/stiff fencing wire to poke and scrape around deep into the engine block and break up the remaining chunks inside so the water from the garden hose flowing through will wash it all out. Leave it running until the water comes out clear and clean.
Cold Weather
Anti-freeze coolant protects the engine cooling system from freezing.
Be sure to check that the coolant has these properties as some don't (most do though).
Failure to do so can result in heater and radiator core damage (the frozen fluid expands and splits them apart) among other things.
Use the correct mixture of concentrate-water. Glycol on it's own actually has a freezing point similar to water on it's own. Adding water actually lowers the freezing point (up to a point, then it raises back up when the mixture becomes too lean)
To enable faster starts and lessen wear in sub-freezing temperatures, consider installing a Block Heater.
SBNLL-C0001 COOLANT-NISSAN LONG LIFE 2 LITTER(0.4
SBNLL-C0002 COOLANT-NISSAN LONG LIFE 4 LITTER(0.8
SBNLL-C0003 COOLANT-NISSAN LONG LIFE 18LITTER(3.9
10125-62200 N.C.S. SEALER (1 CARTON-96
Other Mixtures
Water wetter/race coolant --- Some racing events/facilities forbid the use of ethylene glycol based coolants due to safety concerns/leaves slippery residue on track which is difficult to remove. The system needs to be thoroughly flushed and drained before filling with the appropriate coolant such as Penrite Racing Coolant and Evans Waterless Coolant. Some of these mixtures lack anti-corrosive properties so need to be drained and replaced regularly or replaced with regular coolant between events/storage. Or buy stuff that is anti-corrosive.
Soluble oil --- If the vehicle is using lots of coolant (eg, cracked head/block, bad head gasket etc) and you're too lazy/cheap to fix it and too cheap to keep buying proper coolant, but don't want to damage your engine parts via corrosion, you can use a soluble oil-water mix. This is commonly used in machine shops to cool cutting tools (saws, lathes, drills, milling machines etc) You can usually buy gallon bottles for around the same price as same sized proper engine coolant concentrate, but the mixture is usually a lot leaner (around 250mL of oil to 4L of water) so you can make a LOT of mixture using the one bottle. If you've ever wondered what that oily stuff is in a bottle of Bars Leaks that turns white when mixed in water, that's what it is. The mixture can be topped off with plain water a fair bit before the mixture becomes too lean - top it up with a little more of the oil every now and then to get it nice and milky again. Seems to do the job regarding corrosion protection, but heat transfer, anti-freeze, and condition of rubber parts and whatnot cannot be guaranteed...The mixture does tend to separate after long periods of sitting so it's not recommended for vehicles being stored for long periods.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Coolant"
This page has been accessed 24,943 times. This page was last modified 09:49, 23 June 2021. Content is available under Datsun 1200 Club.
